Nismo Omori Factory & Up Garage In Tokyo
Yeah, guys... heading to Japan mid feb... looking at visiting both Nismo Omori factory and Up Garage.
Just like to see out of all their stores which Up Garage is easiest or closest to Tokyo.... same goes for Nismo factory... it is open to public right? or is it Nismo shop that i am thinking?
Any help will be appreciated!
Cheers
UP GARAGE
tokyo station to chiba, get off at chiba and get onto the local line there and goto chiba chuo ( its about a 5 min walk but recommend you catch the train ) when you get to chiba chuo station you head left down the corridore with shops and out the door , when you get out side you will see a park ( realy just a walking area ) follow that till you hit the foot bridge, walk up the foot bridge till your near the middle ( busy highway under you at this stage )look right and about 100M down you will see the big up garage sign and there you go.
time : 110 min each way
NISMO FACTORY
tokyo station to shinagawa station, get to the keikyu line ( ask someone at the ticket booth as it took me 20 min to find it and i missed the train so had to wait ) and buy a ticket to Omorikaigan, once there exit the gates and the station, head left and you will see a skinny foot bridge to the other side of the road, take it to the other side and head left when you come to the other side , keep walking 10 mins and you will see it .
Nismo factory is only open wed , thurs, fri , sat , sun - 10am to 6pm but the store is only open fri, sat, sun, 1pm - 6pm
Time : about 90min each way
hope it helps
stylz7: Thanks very much!!!! IT certainly help me alot!! :(
Would of thought the store should open longer hours.... anyway, so what is the Nismo factory like? is it a guide tour? and does it cost anything for entry?
Cheers
PS: I have both BNR34 & BNR32 like u!!! :)
I was there last year. They had a Calsonic GTR on show out the front (which you can't get close to), inside there's a shop with a few knick knacks, and a window into the workshop which you're not allowed into. From memory they had an R34 GTR Nur and a 32 GTR of some kind both up on jacks getting looked at. I found it to be a waste of time but you may get something out of it.
Nismo is definatly worth a trip IMO, but they have funky opening hours, so call ahead. If you cant speak Japanese, try asking the person at the front desk of your hotel to call for you. Japanese are VERY friendly and helpful like that!
:P
Theres actually a local train that's closer to the factory. Can't remember the name. The JR line is a fair walk.
Also book into the place to do a tour.. We just rocked up and they didn't have time to show us around :)
  • 1 month later...
Take it from someone who passes Nismo Omori weekly, dont make it your main itinerary. If you are close and can make the trip, great, if not, I would spend my time going to other places where you can see more.
What other places would you recommend?
Im heading to Japan in July and I had pencilled in teh Nismo factory & the Nissan Museum but that's only cos I dont know of anywhere else good to go....
Japan is an AWESOME place and its true the NISMO OMORI FACTORY isnt as good as it looks.
I have been to Japan twice and both times been there. The shop is quite small and they normally dont let u go into the workshop....
But if ur close i guess its worth it.
Top Sercet is another place that took forever to get to and wasnt as good as people make it out to be.
Hey N1GTR how did u get the photos in the workshop??
They didnt allow us to go in there or to take photos
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
