I have for sale the following items:
1. R33 GTSt brake calipers, rotors and pads $500 (If sold seperatly $350 for the Fronts and $150 for the Rears)
2. R33/34 GTR JJR intercooler hard piping kit powdercoated black by Craved Coatings, including silicon hoses $350 (Missing hose clamps)
3. R33 car jacks $30 each
4. R33 push type slave cylinder with line $60
5. RB26 cam cover $60 (will require respray)
6. Exhaust cam bracket $20
7. Stock R33 GTSt BOV with pipe $50
8. R33 GTSt crankshaft and crankshaft girdle $100
9. RB26 badges Large $30 Small $10 each
10. RB20/RB25/RB26 Gates timing belt $80
11. Stock R33 handbrake shoes $50
12. Stock RB25 conrods $60
13. R33 GTSt thermo fan $60
14. R33 GTR front and rear rotors Make an offer
15. Various plugs for radio/headunit $10 each
16. RB26 push in cam cover fitiings -10 size $30
17. N1 oil pump gears $300
18. R33 GTSt manual, series 1 speedo cluster $60
19. Apexi power FC hand controller 415-N001 $350
I am located in Sydney, happy to post interstate at buyers expense
Edited by Smoky
https://www.sau.com.au/forums/topic/302659-rb25-rb26-parts/
  • Replies 40
i'll take this if its the pair of cam covers (like the actual camshaft covers...)
and if these fit the RB25 cam covers i'll take them too
https://www.sau.com.au/forums/topic/302659-rb25-rb26-parts/#findComment-5018200
Sorry, I should have put it as RB26 timing belt cover, no cam covers for sale
To my knowledge they will only fit an RB26
Hi mate, interested in the Apexi Power FC, i still have the stock ecu, is this a plug in piggy back system? or does it replace the whole ecu? thanks, i live in perth btw. oh and it works good?
No Power FC for sale here, just the Hand Controller
https://www.sau.com.au/forums/topic/302659-rb25-rb26-parts/#findComment-5018283
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
