I'm looking into the possibility of getting some 20L drums of Toluene.
Would anyone be interested at between $35-40 for them?
I'll have a definate answer on this after Christmas, and just wanted to gauge the number of people interested?
Disclaimer:
Toluene is for track use only, not for use on State and public roads. I accept no liability for injury, death or damage from its use or misuse. MSDS will be supplied with Drums.
Dan
https://www.sau.com.au/forums/topic/30284-brisbane-only-20l-toluene/
  • Replies 40
Knore: It's used as a fuel additive. It is not a complete fuel. It is usually mixed as a percentage with 98 octane fuel.
Eg: 40L BP Ultimate plus 4L Toluene is a 10% mix.
It allows you to run slightly higher boost or slightly advanced timing without pinging...
I've only ever used it as a safeguard, rather than a power producing thing. And only at the track... No really! :P
It is also commonly refered to as Methyl Benzene, and it is primarily used as a paint stripper...
Google "toluene octane" and check the results... Also do a search on here. Pretty sure it's been discussed before...
Guest darrinspencer
It looks like it'll be $38 for a 20L, how does that sound to you guys?
Dan
Hey Dan, it is Darrin here who you bought your turbo off for your car.
My Dad buys 200L of methanol each month from a company called AFCC in Brisbane near the gatetway bridge south side ph33894844
They sell tolene for $53 +gst for 20L (not cheap) but they also sell it by the 200L drum for $277 +gst which is $304.70
Divide that by 10 equals $30.47 for 20L, but you will need your own 20L drums to split it up.
I can get hold of the pump from my dad to decanter into 20L drums
Let me know if your keen.
I would be interested in 20L myself.
Jay, this can be an ongoing thing depending on demand, I can't see any reason why I couldn't keep up with everyones requirements.
My contact was away today, but I'll have a chat with him tomorrow and get some dates happening.
VIPERGTSR01 - as for mixes it all depends on what octane you're chasing...some people go for 30% mixes...other running serious boost put in straight toluene.
Dan
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
