I think some SE Qld guys should get together sometime, dont really wanna go through all the hassle of organising a cruise but i was thinking we could just organise a sunday that everyone could make it to the spit. I know some ppl don't like the spit but its a good chance to get out and see some nice cars.
What do you guys think? Keen?
https://www.sau.com.au/forums/topic/302939-gold-coast-stag-meet/
  • Replies 76
We'd be up for it as long as it's before the 25th of Jan because we're moving to SA
Maybe post on the Queensland section. There's a Gold Coast Thread.
just trying to get some stags together tho
how about 17th of jan for everyone, not this sunday but the next
if you dont go to the spit on sundays just make an effort and come out and say hello!
Sounds good to me, assuming I'm able/allowed to drive by then... Either way, as soon as I get the all clear from the neurosurgeon, I'll organise another meet/cruise.. Keep an eye on the Stagea sectionin the next few weeks... :rant:
well spit is normally 1ish to whenever, just keen to get everyone together and see some other stags before i head off to tas for uni
if ppl want we could arrange to meet up outside of the spit and go in together, just gimmie some ideas of where you would want to meet
sounds good, i should be free and would like to head down. are we going to have a meeting place for the brissy guys before head to the coast to meet up with the goldie guys?
Edited by QWK32
Just a suggestion,
If we prefer to meet prior to the Spit, we could meet in that car park out the front of Australia Fair facing the Broad Water?
Its close and got a fair amount of room.
I work sunday's in southport opposite pool/park.
Might pop out if i see ya's!
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
