in my other thread people were telling me not to boost it any higher than 12 on the stock turbo.
curious to know what everyone thinks is an ok amount of boost to push through the stock turbo, because ive herd anything from 10-17
car is currently on 10 but contemplating putting its high boost setting as 15.
https://www.sau.com.au/forums/topic/302979-boost-on-a-stock-turbo/
  • Replies 66
stock turbo on mine i had it up to 14psi.....but since after 4800rpm the boost would drop down to 12 and held it flat till redline....
so no point boosting it to 14psi....12psi is much safer and definitely not 17psi
Extended periods on high boost blow the turbo, not just setting it to 17psi.
I could set my turbo's to somehow boost to 30psi, but I might just put my foot down til 10psi then back off... that wont blow the turbo.
But if I kept my foot down at full 30psi boost, that'd blow the turbo.
So your mate wasn't driving his car hard enough to blow the turbo :rant:
Plenty of stock turbos have died at even 10psi when on the track under decent temperature and load .... pretty sure that's how the HPI R34 blew its stock turbo when they did their build-up. 17 is insane and would not last long at all.
so as a daily driver the highest would be 14 if im not flogging its guts out everytime i drive it?
and its safe to say i drive like a grandma with the very occassional spirited drive
*edited* cheers for the advice, just trying to find the highest/safest amount i can put through it when the car wont be thrashed off its guts on a daily basis
Edited by HSV004
My old turbo on my B6T-equipped Mazda could handle 15psi on the odd-occasion. That was even with a side-mount cooler.
Just upped it, flogged it for a few minutes then put it back to 10psi. It happily ran that way for years until the chassis cracked.
And that was a stock little turbo that's only designed to run at 6psi.
off topic a bit, its actually amazing how helpful the import scene is compared to the holden scene towards the new guys.
ive asked several dumb questions on this forum, and had nothing but helpful remarks back.
on other certain forums i wont name, you ask a dumb/basic question and they bite your head off.
so cheers guys.
as i said before i ran mine on 14psi....coz i hardly hit limiter everywhere.....the car ran on that setup for about 2 years without a problem.....till i upgraded the turbine
make sure though you are putting 14psi through a front mount intercooler instead of those poxy little side mount coolers mate
plus i had other mods to go with it like fuel pump, coilpacks etc and a full tune and it made 214 odd rwkw on a el stocko turbo
aren't they around the $1500 mark.
only starting to get cash flow back after a few months without a job. so not looking to spend big $$ just set.
although i can get the labour for pretty much nothing and get things like bigger turbos/injectors for the price of a carton
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
