  • Replies 66
haha i wish it was that easy, i should have explained it better. whatever parts he has spare. which all seem to be upgrades on my current system.
having an ex drifter for a mate is a bonus.
doesnt help him having expensive taste in alcohol though haha
before you go upgrading your injectors or turbo you will need an aftermarket engine management system lol....so investing in a PFC or a haltec or what ever is a good idea....some people even get a RB20 ECU remapped to suit a RB25....or they get a VG30 ECU remapped to suit a RB25...speak to Jeff in regards to that as he is the man with the know how
yeah someone else has reccomended the vg30 ECU path, and i think my mate has one laying around or i may be mistaken. cheers for the help guys
not a bad idea but i would go with the Power FC if i were you mate....got on in the car and its damn brilliant....works a treat and most tuners love them
if you dont have a hand control for the pfc, then the cop would need to pull off the kick panel and know what a "Power FC" is.
Or you can put the standard computer cover on the PFC, then Regency probably wont even know. I know someone who has passed Regency with one :rant:
The PowerFC only supports manual cars (excluding Toyota). It will work on an automatic car however it will not handle gear changes and simply keep the throttle nailed during a gear change. This will result in jerky gear changes and stress placed on the gearbox. The factory ECU during a gear change will communicate with the auto box and drop timing, ignition to ensure a smooth change. For those wishing to use PowerFC with auto you should consider a mechanical auto gearbox instead of an electronic. The PowerFC should work fine with a mechanical gearbox such as power glide, transbreak etc.
This is because the mainstream ECU's in Nissan etc rely on the main cars' ECU for gear logic change control and functions. Cars such as the Toyota have a seperate ECU for the gearbox change logic and control so it's not affected. Apexi chose not to port the Automatic gearbox logic code (as its very long and complex) into the PowerFC because I suspect they found its simply not worth it & too complicated. You can buy an Automatic PowerFC for a Toyota Chaser for example and it has auto logic control under SETTING, you can set the shiftmap, ramp up speeds etc as it has the code to interact with the Toyota AUTO ECU that is seperate to the main ecu. So in summary - Auto PowerFC's exist & work but only for Toyota. We have seen quiet a few Auto R33 Skylines with manual PowerFCs - some report they work fine etc and there is no difference - do so at your own risk.
Thanx for the info damo is there anything you would reccomend to run on the auto as a replacement for a pfc or is it pretty much jus buy a manual car lmao??
Tis what I did! :rant:
If keeping the auto ... an Apexi SAFC and SITC can do the job nicely.
:rant:
Ruby how much did it cost you to get the manual put in and who did it??
The safc and sitc are they 2 diff things if so which would you reccomend?
I fitted the box myself with Luke's help. Took our time and ensured we did it right and it went in without a problem.
The SAFC (super air flow controller) allows you to control fuel ratios (to a limit) and the SITC (super ignition timing controller) allows you to make timing changes. If you can only get one, get the SAFC first as sorting out your fueling issues should come first. Tho the SITC is cheaper, but harder to come by.
Thank-a-you Damoo and Ruby will need to pm u n find out sum info about the manual conversion parts prices etc considering doing it :)
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
