Internet In Narre Warren
  • Replies 88
narre warren huh? you poor poor boy..
i think you can get ADSL down there these days and i think cable too.. although seeing as every house is pretty much a housing estate, might have problems with pair gain..
netspace is one of the best ADSL providers/price/benefits i reckon. Either that or some of bigblue has some decent rates. Stay WELL WELL WELL clear of telstra. Shittest internet i ever had, email servers down, authentication problems still years after they first came on, high priced, the list goes on..
Fountain Gate, what a place :D
You can check the availability of cable for telstra and optus.
OPTUS
http://www1.optusnet.com.au/offers/cable/a...=optusnetportal
Sorry but cable is not available in that postcode area (3804).
Telstra needs an address to tell you if cable is available in the area...
However, we live in a cabled area, and can't get Optus.
:Bang:
because we got optus tv at our old house about 6 months ago with internet deal optus told me i have to pay $340 to disconnect, i told them to shove it up their ass becasue its their problem they dont provide cable in narre warren and because i have used optus cable fro around 4 years.
i will have to search around for some good broadband or asdl, and gordo i am in a housing estate and their is lots of free land with no cops around for me to test my car out
You can try, but it won't get you very far. You'll have to keep paying each month or the cancellation fee, or eventually they send debt collectors after you. I had ADSL for 18 months - and to move cost me $100 (that wasn't the bad part) PLUS i had to be on a whole new friggin contract for 12 months. I yelled and abused them, but in the end one of the managers told me it was Telstra's fault and telstra locked them into paying some backend fee to transfer whether a new or existing user. In the end i said stuff it, and hence why i haven't been on ADSL since :D
Yes and no :D There are quite a few cameras in narre and cops late at night like to sit on the nice open streets and book people just 'cause - but there are some good parts. I used to go out there a bit coz a friend lived out there.
    • Thanks for that mate always a good help
    • It's not really a calibration issue, if the voltage is really at 2V. If the voltage is 2V, then that's what the TPS is putting out, and the Haltech is seeing that and 2V is about 40% open (you know, between 0.45v being closed and something close to 4.5V being fully open). So, that would suggest that the TPS is maladjusted, on crooked, something something something. Or a wire problem.
    • Hi guys my TPS voltage is reading over 2v at idle.  My Haltech ECU is reading around 40% throttle position at idle also which is really strange. Note the actual throttle position sensor is brand new…    anyone have any experience with this or know how to calibrate it on Haltech ?
    • The OEM disk will not work on any AEM ECU, you need to use the one they made. You shouldn't have to flip the CAS or whatever you were describing, if you set the ignition sync offset correctly it can't backfire. Make sure you're using a spark plug lead on coil 1 instead of the timing loop to avoid weird issues with the timing light. Double check that your timing settings are actually correct, like is the 24 tooth configured correct or should it actually be 12 teeth for 1 crank revolution? I also found this: 305817248-AEM-Undocumented-Settings-v1-2.pdf
