Item: 1998 R34 GTT coupe 74000KMS
Price and Payment Conditions: $21000!!
Factory stock standard exc cond in/out. Low kms. std. 206 kw 2.5ltr NEO TURBO warranty and log books, only mod BOV,Apexi turbo timer - Pioneer AVH-P5750 DVD player with VDP installed.
Car serviced before every 10000km interval. Comes with warranty. The cars engine has been kept stock standard apart from the gfb blow off valve. Stock Bronze wheels.
Extras Include:
Spitfire coil packs
Body kit Impul front bar + side skirts
NISMO Genuine ZTUNE LED TAIL LAMPS
NISMO GEAR KNOB
NISMO clear indicators front & side
Pioneer Vehicle Dynamics Processor
Kicker 12" comp. sub ect.
Apexi turbo timer
Deceptor Pro blow-off valve electronic in-car adjustment of blow-off valve volume lets you choose when and where you are noticed!
Contact Details: 0418989447 or pm
***WILL ONLY SWAP FOR A R34 GTR OR CHEAP DAILY (a get around car under $5k) + CASH*** NO OTHER SWAP OFFERS PLEASE! DO NOT PM ME ASKING TO SWAP YOUR COMMOS OR SUBARUS OR FORDS ECT. UNLESS THEY'RE WORTH LESS THAN $5000 I DO NOT WANT YOUR CAR!!!
Edited by TommyR34
https://www.sau.com.au/forums/topic/303436-1998-r34-gtt-coupe-74000kms/
  • 4 weeks later...
  • 4 months later...
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
