  • Replies 40
been a bit slow off the mark, work keeps pulling extra bits and pieces on me so havent done much. k frame has been changed over, and the front coils are in. steering will get re-attached in a week or two (once back from whyalla), and a couple of new purchases will be made too. not going to look as extreme initially to the eye, but those with a keen eye will notice the good bits
a small question has come to mind. what would people recommend for cooling system. clutch fan is out of the question now as the motor will be sitting a bit too close, especially if i run a thicker rad, so im going with thermos
im lookin at alloy R33 radiators, just cant decide whether 42mm or 60mm is better / more effective?
and using thermos as a push through, what size is better? a pair of 12" or a single 15" fan
I would run twins with a stagered start (ie:one comes on then the other). Also have you thought about putting in a r32/3/4 rear cradle?? Mate had a 31 with a 33 cradle in it for better set up in the rear end. So far its only tacked in so can not say how well it works yet.
Cheers
Ross
Cheers
Ross
i would, but its an aus-del, so its got a live axle. makes it a bit hard to put an irs cradle in. if it was a HR31 that would have been my first mod :D
hard... yes.
impossible... no.
worth it... probably, maybe, sorta, dont really know.
all i know is i hated the live axle in my r31.. i replaced every bush in the back end and it still just didnt feel tight.
hard... yes.
impossible... no.
i'll agree there, i ended up finding some bushes that tightened the rear, and they were the Super Pro bushes. Nolathanes were shit
Now just tryin to get hold of some slotted R33 GTSt rotors, dont want to pay DBA prices LOL
i received some goodies in the mail yesterday, some new hubs and a 42mm triple core radiator :P
car is now on a body trolley (pics when i grab my camera from the car) and the front and rear ends are out again.
diff goes off to be built in the first week of april, hubs should be changed over in the next week or so
photos of progress as promised. doesnt look like much but so much easier to work on now. tomorrow the rest of the pedal box, brake master, front brake lines, steering column and footwell sound deadening get removed
windows will also be coming out so we can start some rust repairs
  • 3 weeks later...
thanks andrew, i'll be sure to ask for some help when assembly starts ;)
good news, my diff is getting built this coming week. went in last week to order my axles, and it seems my order did make last months shipment.
so my standard borg warner 8.5" diff will be equipped with
Moser billet 31 spline axles (standard R31 length, carries same bearing carrier), 5x114.3 stud pattern
Moser full spool centre
retaining the 3.89 auto diff ratio
diff itself gets stripped down, put in the acid bath for a day, then sent off to another local bloke to be etch primed and painted up. comes back, new seals, axles, centre, studs and bearings in and a new dose of oil
this week has bought some good news and bad news, mostly good
cage quote done, getting a basic 6 point cage, plus some extra bar work (one important one for future plans is the sill bars), the parcel shelf pretty much chopped out and a new rear firewall panel. this work is all being done by Craig Helps at Helps Metalwork (http://www.helpsmetalwork.com)
before that can be done, its gotta be sandblasted (which is surprisingly cheap and only takes a couple of hours). that will be done the day before it goes in for the cage (so that Craig has a lot of nice surfaces to weld to)
currently making seat rails for my Sparcos, they'll be in before it gets caged too
picked up my Bosch 044 pump and cradle from Autosport, and with some discussion found out not only can he get all my brake and clutch lines i need made up to suit the pedal box (and from the solid lines to the calipers) they can all be ADR approved too.
Turbo wise...........the original plans for an external gated 3071R have been thrown about a bit
Peter had a talk to Garrett, and even though they've been done, they havent been done successfully. So they're steering away from them now.
Im now going towards:
3071R front housing
Nissan proprietary rear housing (roughly RB25DET size, but in a new casting rather than a used one remachined)
Internal gate blocked off
Having seen one of these new ones on display (was a 2871 front with the internal gate retained), theres a lot of meat around the rear housing for any machining that needs doing. its only going to cost an extra 100 bucks all up on what id originally been quoted for the "proper" 3071
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List: 1.Anna S 2. Luke S 3. Jesse Givens-Lamb 4. Luca Stamatescu 5. Madeleine Stamatescu
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
