  • Replies 40
been a bit slow off the mark, work keeps pulling extra bits and pieces on me so havent done much. k frame has been changed over, and the front coils are in. steering will get re-attached in a week or two (once back from whyalla), and a couple of new purchases will be made too. not going to look as extreme initially to the eye, but those with a keen eye will notice the good bits
a small question has come to mind. what would people recommend for cooling system. clutch fan is out of the question now as the motor will be sitting a bit too close, especially if i run a thicker rad, so im going with thermos
im lookin at alloy R33 radiators, just cant decide whether 42mm or 60mm is better / more effective?
and using thermos as a push through, what size is better? a pair of 12" or a single 15" fan
I would run twins with a stagered start (ie:one comes on then the other). Also have you thought about putting in a r32/3/4 rear cradle?? Mate had a 31 with a 33 cradle in it for better set up in the rear end. So far its only tacked in so can not say how well it works yet.
Cheers
Ross
Cheers
Ross
i would, but its an aus-del, so its got a live axle. makes it a bit hard to put an irs cradle in. if it was a HR31 that would have been my first mod :D
hard... yes.
impossible... no.
worth it... probably, maybe, sorta, dont really know.
all i know is i hated the live axle in my r31.. i replaced every bush in the back end and it still just didnt feel tight.
hard... yes.
impossible... no.
i'll agree there, i ended up finding some bushes that tightened the rear, and they were the Super Pro bushes. Nolathanes were shit
Now just tryin to get hold of some slotted R33 GTSt rotors, dont want to pay DBA prices LOL
i received some goodies in the mail yesterday, some new hubs and a 42mm triple core radiator :P
car is now on a body trolley (pics when i grab my camera from the car) and the front and rear ends are out again.
diff goes off to be built in the first week of april, hubs should be changed over in the next week or so
photos of progress as promised. doesnt look like much but so much easier to work on now. tomorrow the rest of the pedal box, brake master, front brake lines, steering column and footwell sound deadening get removed
windows will also be coming out so we can start some rust repairs
  • 3 weeks later...
thanks andrew, i'll be sure to ask for some help when assembly starts ;)
good news, my diff is getting built this coming week. went in last week to order my axles, and it seems my order did make last months shipment.
so my standard borg warner 8.5" diff will be equipped with
Moser billet 31 spline axles (standard R31 length, carries same bearing carrier), 5x114.3 stud pattern
Moser full spool centre
retaining the 3.89 auto diff ratio
diff itself gets stripped down, put in the acid bath for a day, then sent off to another local bloke to be etch primed and painted up. comes back, new seals, axles, centre, studs and bearings in and a new dose of oil
this week has bought some good news and bad news, mostly good
cage quote done, getting a basic 6 point cage, plus some extra bar work (one important one for future plans is the sill bars), the parcel shelf pretty much chopped out and a new rear firewall panel. this work is all being done by Craig Helps at Helps Metalwork (http://www.helpsmetalwork.com)
before that can be done, its gotta be sandblasted (which is surprisingly cheap and only takes a couple of hours). that will be done the day before it goes in for the cage (so that Craig has a lot of nice surfaces to weld to)
currently making seat rails for my Sparcos, they'll be in before it gets caged too
picked up my Bosch 044 pump and cradle from Autosport, and with some discussion found out not only can he get all my brake and clutch lines i need made up to suit the pedal box (and from the solid lines to the calipers) they can all be ADR approved too.
Turbo wise...........the original plans for an external gated 3071R have been thrown about a bit
Peter had a talk to Garrett, and even though they've been done, they havent been done successfully. So they're steering away from them now.
Im now going towards:
3071R front housing
Nissan proprietary rear housing (roughly RB25DET size, but in a new casting rather than a used one remachined)
Internal gate blocked off
Having seen one of these new ones on display (was a 2871 front with the internal gate retained), theres a lot of meat around the rear housing for any machining that needs doing. its only going to cost an extra 100 bucks all up on what id originally been quoted for the "proper" 3071
    • Did this end up working? Did you take some pictures?
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
