has a couple of creases on the roof from where the old bonnet blew up a while ago. got quoted $220 to fix it good off the dingo dents guy. i never got it done coz it doesnt bother me too much. was going to but didnt
price: $13000 will swap for cars, bikes, boats. jetskis, hookez
selling my r33. current rb25 motor has low compression on 6th cylinder. its down to 50 psi or so.
- registered until 4th month sometime
have a rb30 rebuilt bottomend with
- new mahle pistons and rings
- crank collar
- new king bearings
- hole drilled for 2nd tensioner to put twincam head on
- grub screwed crank
- bored 1mm oversize
- ready to put rb25 head on
and have a rb25det head all rebuilt. fair bit was done to rebuild it like new. has had the welding mods done and new vct fitting attached ready to put on rb30 block. tapped threads to put the rear oil drain in.
- have new nissan headgasket
- new nissan headbolts
- bottomend gasket kit
- top end gasket kit
parts on car
- exeedy ceramic button clutch that slips when you cain it. replacement clutch plate is $250 delivered but the car come with a good new clutch
- blow off valve
- 3 inch exhaust
- 17 inch wheels (not that good but)
- all tyres are good
- 400r bodykit with standard front bar
- 5 speed manual
- cd player
- front mount intercooler
- front facing plenum
- probably few more things but its just the basic upgrades
parts that come with the car
- new motor setup
- npc bigmouth track clutch rated to 400kw
- new billet flywheel
- greedy copy plenum kit (plenum-80mm throttle body,fuel rail)
- spool imports head rear oil drain kit
- proboost 38mm wastegate
- highmount stainless turbo manifold
- wolf 3d v4 plugin ecu
- will update any other bits i have
car blows fair bit of smoke after boosting. thought it was turbo seal but after doing a compression test id say its from the low compression piston. made 250rwhp couple of months ago with the problem. its got fair bit of good stuff to make it good. just needs to all be put in
selling the car with all the parts as a package. just needs few other parts like turbo and injectors and itl hamma. can get a proboost to4z turbo for about $800. did have one but sold it. was aiming to make 450rwhp with all this stuff.
- located on northside of brisbane
- pm me if your keen
https://www.sau.com.au/forums/topic/303654-r33-2-door-skyline-400r-bodykit/
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
