has a couple of creases on the roof from where the old bonnet blew up a while ago. got quoted $220 to fix it good off the dingo dents guy. i never got it done coz it doesnt bother me too much. was going to but didnt
price: $13000 will swap for cars, bikes, boats. jetskis, hookez
selling my r33. current rb25 motor has low compression on 6th cylinder. its down to 50 psi or so.
- registered until 4th month sometime
have a rb30 rebuilt bottomend with
- new mahle pistons and rings
- crank collar
- new king bearings
- hole drilled for 2nd tensioner to put twincam head on
- grub screwed crank
- bored 1mm oversize
- ready to put rb25 head on
and have a rb25det head all rebuilt. fair bit was done to rebuild it like new. has had the welding mods done and new vct fitting attached ready to put on rb30 block. tapped threads to put the rear oil drain in.
- have new nissan headgasket
- new nissan headbolts
- bottomend gasket kit
- top end gasket kit
parts on car
- exeedy ceramic button clutch that slips when you cain it. replacement clutch plate is $250 delivered but the car comes with a good new clutch
- blow off valve
- 3 inch exhaust
- 17 inch wheels (not that good but)
- all tyres are good
- 400r bodykit with standard front bar
- 5 speed manual
- cd player
- front mount intercooler
- front facing plenum
- probably few more things but its just the basic upgrades
parts that come with the car
- new motor setup
- npc bigmouth track clutch rated to 400kw
- new billet flywheel
- greedy copy plenum kit (plenum-80mm throttle body,fuel rail)
- spool imports head rear oil drain kit
- proboost 38mm wastegate
- highmount stainless turbo manifold
- wolf 3d v4 plugin ecu
- will update any other bits i have
car blows fair bit of smoke after boosting. thought it was turbo seal but after doing a compression test id say its from the low compression piston. made 250rwhp couple of months ago with the problem. its got fair bit of good stuff to make it good. just needs to all be put in
selling the car with all the parts as a package. just needs few other parts like turbo and injectors and itl hamma. can get a proboost to4z turbo for about $800. did have one but sold it. was aiming to make 450rwhp with all this stuff.
- located on northside of brisbane
- pm me if your keen
https://www.sau.com.au/forums/topic/303655-r33-2-door-skyline-400r-bodykit/
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
