Been having a discussion on supraforums about whether or not the end muffler has any major effect on the sound a car puts out. Obviously the difference between a 1" pee shooter and a 5" cannon will be different, but if you had two of the same car, with the same set up all the way back to the rear muffler would two different cannons make a large difference to the noise? I figure a cannon is a cannon and brands will only change the note slightly.
Anyway, the reason I'm bring this here is because I currently have a Varex muffler on my car, but my car is quiet enough not to need it in the first place. A mate of mine wants to buy it off me, so I told him to buy me a replacement and I'll give it to him for free.
IF there is a difference, can anyone recommend me a decent muffler only (not interested in a catback, already have a custom system) to replace mine with? I asked on the Supra forums but compared to SAU they're utterly dead.
Thanks for any input guys, and sorry for bringing another exhuast thread in here. :huh:
https://www.sau.com.au/forums/topic/303709-mufflers/
the shape and size of the muffler plays a big part on how it sounds. if you get 2 cannons roughly the same size then they will more than likely sound very similar. but if you get a cannon and compare it with a big oval muffler then the sound will be totally different as the oval mufflers have a lot more packing in them and generally make the car quieter and generally give a less raspy sound.
a perfect example is some of the lancers etc you see getting around. they have cannons on them and often sound like a rotary once they floor it. yet if you see one with an oval muffler on the rear they just sound a bit deeper and louder than normal and don't usually sound like arse.
as for cannons being cannons, as i said to start with, size comes into it as a bigger bodied cannon will be quieter than a smaller bodied cannon with the same pipe though the centre. this is because they have more packing in them to soak up the sound. also better quality cannons will generally be quieter as well for the same size body simply because they put more packing in them and better quality packing.
https://www.sau.com.au/forums/topic/303709-mufflers/#findComment-5032141
Thanks for the info mate.
I actually wrote out a rather long and indepth reply then got some error when I tried to post it and lost it.
I was mainly asking if different materials have an effect, like titanium, and what kind of effect.
Also, what would recommend for me. I want to keep my racey, high-pitched note, or even improve it.
Cheers.
https://www.sau.com.au/forums/topic/303709-mufflers/#findComment-5034847
It will. Different materials will have different tones. I'm not sure how much volume itself will be affected.
Mild steel tends to have a deeper tone than stainless. Titanium exhausts tend to be very thin-walled, which makes them a bit tinnier as well.
https://www.sau.com.au/forums/topic/303709-mufflers/#findComment-5035451
yeah the same goes for stainless. it is usually slightly thinner than mild steel as well, so gives a slightly different note. however for the actual muffler itself this effect is lessened compared to the piping as there is the muffler packing to reduce the difference.
https://www.sau.com.au/forums/topic/303709-mufflers/#findComment-5035798
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
