Been having a discussion on supraforums about whether or not the end muffler has any major effect on the sound a car puts out. Obviously the difference between a 1" pee shooter and a 5" cannon will be different, but if you had two of the same car, with the same set up all the way back to the rear muffler would two different cannons make a large difference to the noise? I figure a cannon is a cannon and brands will only change the note slightly.
Anyway, the reason I'm bring this here is because I currently have a Varex muffler on my car, but my car is quiet enough not to need it in the first place. A mate of mine wants to buy it off me, so I told him to buy me a replacement and I'll give it to him for free.
IF there is a difference, can anyone recommend me a decent muffler only (not interested in a catback, already have a custom system) to replace mine with? I asked on the Supra forums but compared to SAU they're utterly dead.
Thanks for any input guys, and sorry for bringing another exhuast thread in here. :huh:
https://www.sau.com.au/forums/topic/303709-mufflers/
the shape and size of the muffler plays a big part on how it sounds. if you get 2 cannons roughly the same size then they will more than likely sound very similar. but if you get a cannon and compare it with a big oval muffler then the sound will be totally different as the oval mufflers have a lot more packing in them and generally make the car quieter and generally give a less raspy sound.
a perfect example is some of the lancers etc you see getting around. they have cannons on them and often sound like a rotary once they floor it. yet if you see one with an oval muffler on the rear they just sound a bit deeper and louder than normal and don't usually sound like arse.
as for cannons being cannons, as i said to start with, size comes into it as a bigger bodied cannon will be quieter than a smaller bodied cannon with the same pipe though the centre. this is because they have more packing in them to soak up the sound. also better quality cannons will generally be quieter as well for the same size body simply because they put more packing in them and better quality packing.
https://www.sau.com.au/forums/topic/303709-mufflers/#findComment-5032141
Thanks for the info mate.
I actually wrote out a rather long and indepth reply then got some error when I tried to post it and lost it.
I was mainly asking if different materials have an effect, like titanium, and what kind of effect.
Also, what would recommend for me. I want to keep my racey, high-pitched note, or even improve it.
Cheers.
https://www.sau.com.au/forums/topic/303709-mufflers/#findComment-5034847
It will. Different materials will have different tones. I'm not sure how much volume itself will be affected.
Mild steel tends to have a deeper tone than stainless. Titanium exhausts tend to be very thin-walled, which makes them a bit tinnier as well.
https://www.sau.com.au/forums/topic/303709-mufflers/#findComment-5035451
yeah the same goes for stainless. it is usually slightly thinner than mild steel as well, so gives a slightly different note. however for the actual muffler itself this effect is lessened compared to the piping as there is the muffler packing to reduce the difference.
https://www.sau.com.au/forums/topic/303709-mufflers/#findComment-5035798
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
