what car
87 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Ok guys looking at new car.
dont wona spend above 10k and i got save some money.
im considering a S14 silvia, R32 GTS-T, 180SX
all around the 10k mark easerly avalerble, and most have work done.
just wondeing what people would buy.
am gona use it as a daily and drift/track.
https://www.sau.com.au/forums/topic/303744-s14-180sx-r32/
  • Replies 41
Drift use - 180/S14.
What I have personally found (and with others) 32 need some attention to incrase lock. Some options are simple and cheap, others not so much. Either way, its time and money that must be spent if you want to be on par with S platform in terms of angle.
The benefit of a 32 is RB power & torque
https://www.sau.com.au/forums/topic/303744-s14-180sx-r32/#findComment-5032688
unless you are on your p's and the restrictions are preventing you from getting a r33, i would go the 33. for drift, etc they are very easy to drive as the torque is much better than the 2.0L engines. the extra toque means you don't have to be changing gears as much if the revs start to drop.
out of the other options, i personally would go the s13 over the s14 because i prefer the look of them. for drifting i would also rate the sr20 over the rb20 as the sr puts out more torque, especially if you happen to find one with the later model BB turbo on it. also in a straight line the s13 and s14 are quicker than the 32.
https://www.sau.com.au/forums/topic/303744-s14-180sx-r32/#findComment-5033699
No restrictions up hear in darwin Plus im 23.
Dont wont a 33 as i dont like the shape. but dont forget it's just not drift use. would also be circute and daily driver.
https://www.sau.com.au/forums/topic/303744-s14-180sx-r32/#findComment-5034168
fair enough, then in that case, 180sx or s14, depending on what you like the look of more. if you go the s13 then just get a BB t28 turbo off a late model s14 or s15 and you'll be laughing. they go good on 15psi even with the stock ecu (or even with the stock bush bearing t25 turbo at 15psi).
https://www.sau.com.au/forums/topic/303744-s14-180sx-r32/#findComment-5034392
get a s13 . spend the extra $ on a s14 F/L motor and box and stage one mods . can be done easy for under ten and itll go mint . mate has done it . does 13.0's on street tires on unprepped track . also has justies and mostly aftermarket arms for that price
https://www.sau.com.au/forums/topic/303744-s14-180sx-r32/#findComment-5034791
mmmm,
Is intresting i think im gona have to drive all of them and find out (well ive driven a stock auto 180sx) was ok but i prefered th r31 that i had at the time as the 6 just had way more punch even tho the 180sx was a tad behind the 31 (1/2 car),
the idea of a cheep s13 and using the spear cash is good. but how may would i find that arnt farked to oblivion?
https://www.sau.com.au/forums/topic/303744-s14-180sx-r32/#findComment-5037883
s14 is newer and has an updated chasis which is much better than the s13/180sx ones. Series 1 s14's do not look very good to me but thats personal opinion there are ones i have seen that have looked awesome just rare to find.
S14 would def be my choice out of the 3 but i guess if you do mod the car a lot it won't matter that much with the stock chasis differences
https://www.sau.com.au/forums/topic/303744-s14-180sx-r32/#findComment-5037977
s14 the car is almost drift ready 5 stud decent brakes engine is ready for 200kw with boost fmic and exhaust all they need is coilovers and a 2way
compared to the 32.
The one thing i dont like about the s14 is the rear end.
I think ive narrowed down to 32 v 14. how hard is it to put a RB in the s14, that could be the substerute 6cyl end in a decent cahssies. but if i did that why not keep it in the skyline?
https://www.sau.com.au/forums/topic/303744-s14-180sx-r32/#findComment-5038639
compared to the 32.
rb20 or 25?
personally the 25 is the better option or you could go 1jz.
read over these build threads:
http://www.nissansilvia.com/forums/index.p...401228&st=0
http://www.nissansilvia.com/forums/index.p...374506&st=0
http://www.nissansilvia.com/forums/index.p...p;#entry5436683
then again you could get an r32 with a rb25. if i could legally drive a r32 with 25 conversion that's what i would have tried to get however, i cant so went with the s14.
https://www.sau.com.au/forums/topic/303744-s14-180sx-r32/#findComment-5038966
S14 = Newer and less popular than the S13
You'll pay out the ass for a '97 Type X, or get a similar condition '98 model S14 for your budget.
and at the end of the day, the type x 180sx still only has a redtop in it (although the rocker cover is black) as it has no VCT like the blacktop in the s14.
https://www.sau.com.au/forums/topic/303744-s14-180sx-r32/#findComment-5039230
below $10k, you ll be looking at a rough s14 series 2, in my experience in searching the past few months or a clean s14 series 1. i'm getting a '95 s14 manual, stock for the most part with 185,000kms for $8500. yeh, seems worn but the engine compression was far stronger then a series 2 i tested for $9.5k with 135,000kms.
i wouldn't worry so much about kms, instead focus on engine compression and vehicle inspections.
https://www.sau.com.au/forums/topic/303744-s14-180sx-r32/#findComment-5039638
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
