I recently got some custom plates for my R32 GTR , i tried bending the old bracket to fit this did not work , also didnt want to bend the ends or cut the ends of the number plate off to fit on the front as this looks untidy , i have limited mechanical knowledge and time but this is what i came up with !
Got some zenith 100 x 100, 90 degree steel brackets from bunnings hardware :D and drilled new holes in them , so the plate would fit flush to the front bar using the three existing mounting screws .
Cut some pieces of 2mm powdercoated plate the same size as the front plate and the rear plate with a grinder. Rivetted the 2mm plate to the brackets for strength and drill holes to mount plates in corners
Remove front bracket again (undo underside screws) , paint both steel plates , Do the same job with the rear but use existing mounting bolt holes as fixing points for big rivets (works great ) drill two new holes on the bottom of rear bracket depending on what size plate you have, i went for square rear , slim front .
Finally rivet custom plate onto steel backing plates to make them harder to thieve ! :P paint rivets black to make good !
Edited by blingtr
https://www.sau.com.au/forums/topic/303763-better-way-to-fit-number-plates-r32/
  • 4 weeks later...
  • 1 year later...
  • 4 weeks later...
I done my number plate bracket yeste , came out as a massive success, i thank you Mark for your tutorial :) the only thing i changed was i measured a marking on the L bracket then drilled holes all the same length so the number plates were flush with the bar rather then sticking out 1cm or so..
great tut :)
(Y)
thanks so much.
good tutorial but would've been a better idea to screw the # plate down rather then rivet it lol
As he said rivet them to make it harder for the plates to be stolen.
Good tutorial....definitely looks awesome!!! :thumbsup:
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
