hi guys i have a vl which is a pretty good car and i have always been a holden man but my mate took me for a spin in his silvia and wow its pretty good
so would a silvia be a good idea if i wanna do a bit of drifting in the back streets cos my vl cant drift i think its not that good maybe because its a v6 so pretty crap and silvias are turbo arent they
or maybe a skyline r32 would be good for drift to i asked this question on nissansilvia.com but noone was very helpful so i hope you guys can help thanks
https://www.sau.com.au/forums/topic/303839-looking-at-maybe-an-import/
Or just turbo your VL!
You're buying the car for the wrong reason.
People who have an attitude like yours are the reason hoon laws were brought in.
Take your attitude to the track and leave it there.
My opinion - Buy a Suzuki Mighty Boy.
im not sure if you are joking about the suzuki cos i dont think they would drift easy at all
and whats the problem if its in the back streets where people wont be around and it wont hurt anyone really plus the track is too expensive
um... lol? my first car was a VL and my next car was a n/a silvia. The silvia was such a better car there was no comparison whatsoever. both about the same speed...but ride/build quality didn't exist in the VL.
no you can get n/a silvias but in any case if I see you drifting in any streets near where I live you better hope the cops get to you first...
cant understand why that would be the case...
anyways, by all means buy a silvia or 180sx - both are great for drifting due to being fast and very light (especially the back end) but in any case - drifting doesn't belong on public roads. and if you drive like that then neither do you!
Edited by pixel8r
Successful Troll is Successful
Holden VL's are Straight 6 engines...
You sure you know what you got?
:thumbsup:
my vl will beat you fagna anytime its a shame its fwd because that instantly makes you gay where do you live i wouldnt mind doing a drag with you in a back street
fagna, thats a good one, mever heard that one before :(
if you were actually serious i would give you a go at calder, although thats probably too expensive for your full sick VL.
Some one needs to learn about car's.
The vl can drift there are two with top end drift associan that drift quite well
the eng in the vl is the same as the R31 skyline
Serosly a vl is worth only about 4k a r34 gtt is about 25k so you would pay him the cash and why would he wont a vl anyway they are plaged with problems v thr r34 (and even r31)
Think you should stick with your vl and be fully sick in that and let the cops catch you on the street's. at least it may take the heat of imports then
Guest
    • Did this end up working? Did you take some pictures?
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
