So i was wondering, how am i supposed to bleed my coolant system with the greddy IM installed?
In none of the isntallation guides was there any mention of how to hook up the bleeder valve
also, what kind of brackets has everyone used to be able to use the stock r33 throttle cable?
mine has the stock bracket for the throttle cable that came off the stock plenum. Just have to bend it and play around with the throttle cable to get it to work. It sits at a bit of a funny angle but it still works.
As for bleeding, the highest point of your cooling system should be your top tank of your radiator. I just bled mine by running it till the thermostat opened and topped up till full. It takes a while
Yeah it seems like some cables are a little longer... mine was about 15-20mm to short... i could get it to reach but it was really tight... i followed the instructions on the greddy instruction manual but to no luck...
i just like to put mine o an incline to be sure..
Head down to your local autobarn. Say that you want a ''GReddy throttle body adapter for rb25det''.
The kit comes with an adapter to fit your stock t/b, but most importantly, it comes with a pre-fabbed bracket for your throttle cable.
too bad i dont live in australia lol
You can still hook up the bleeder, Have a look at this link, shows you how to do it.
http://www.skylinesaustralia.com/forums/to...html&st=160
wools i checked out the picture.
problem is i will be running a non watercooled turbo so that diagram wont work for me
guess i'll just have to get a radiator breather tank
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
