Wtb - Garrett Gt3582r - (gt35r) - (gt35/40r)
Hey Guys, im lookin for a damaged or really crappy GT3582R, must be an external wastegate type with T3 flange and have a 4bolt flange on the rear housing, dont mind on the size of the housings as i plan on taking the turbine out and swapping it with my good GT3582R so i can use it on the street as a P plater. sucks but thats the best way, as i am at the track pretty often running a turbo setup. Max i will spend is $200 and im on the Gold Coast. TELL ME WAT YA GOT!
https://www.sau.com.au/forums/topic/304518-wtb-garrett-gt3582r-gt35r-gt3540r/
when you were a baby.. did your mum drop you on your head?
nope did that happen to you? if not shut up, its my first car and makes 360kw with the turbo setup, so i dont see why i should dismantle the whole lot to use it on the street. and im at the drags once a month and even more often at lakeside and qld raceway. all i gotta do is unplug the apexi power FC and plug my standard computer in with my piggyback and get it tuned after i find the turbo housing's. been in the planning for a long time so it will work.
