Annoying problem that's crept itself up, on very very light throttle, the engine stutters a little, like, super light throttle (1k-1.5k~ or so RPM while in neutral) - it's not the throttle cable either because it does it when you manually give it throttle off the throttle body.
Any ideas?
Giving it a tad more throttle and it's no problems. It just makes the ride really jerky sometimes when driving in like 2nd gear at low throttle. It's an RB25DET throttle body (S2)
Cheers.
https://www.sau.com.au/forums/topic/304572-light-throttle-issues/
Sounds like its running lean there, possibly due to the airflow meter being dirty. Give it a clean first with a can of CRC airflow meter cleaner and see if that fixes the issue first.
Cheers, I don't have any CRC AFM cleaner, will something like Isopropyl Alcohol work?
Yup, isoprophyl alc is good, absorbs water & leaves no residue, also check plugs for gaps, & coilpacks for moisture & crap that will make things (sparks) track. give the coilpaks a wash with the iso & spray with a silicon inhibitor. Quote gospel from PI #116
Cheers GW
are you using an aftermarket ECU?
add some more accel enrichment and see how you go
Nah, just a standard chipped ECU, it hasn't always been an issue and just seems to be intermittent, it barely did it at all on the way to work this morning. I'm still at work though so haven't tried the cleaning stuff yet.
FULL RABBIT OR NO RABBIT!!!!!! noone likes a tortoise, light throttle is for wimps.
Haha, unfortunately that doesn't work so well in peak traffic :(
Plus, I wish my car had a lawnmower style throttle instead of an accelerator pedal :P:D
ok so you want it fixed then.
afm or sticky butterfly would be a good place to start... get out with some carby cleaner.
slight vacuum leak.
dodgy injector, may be spraying to much or dribbling out and flooding one cylinder or not spraying enough due to blockage and running lean in one cylinder.
dodgy plug, same as dodgy injector but different.
Well I just sprayed the AFM and all the coilpacks with iso alc - left it for a bit to dry then fired her up, it was doing the up n down up n down up n down revs at low throttle still but only for like 10 secs, from then on it seemed all good.
I didn't have any long sockets for the spark plugs but will find some if it happens again over the next few days.
Cheers guys.
Changed the spark plugs, no difference - thought I wanted to change them anyway :) (and only $20NZD for the set, can't go wrong)
Until on my way home, hit a little boost and FSHHHHH, the silicone joiner between the turbo and the intercooler piping blows off.
I have a feeling this has been the problem all along, leaking out of top of this joiner.
Gotta try my best to get it on real good tomorrow morning, will post back results.
good work man... that will do it. hope its all good.
Yeah cheers, I tried my best but I think my hose clamps are being shit as well as the 90 degree silicone bend.
Getting a 90 degree stainless welded onto the end of the intercooler piping to eliminate the 90 degree silicone bend and put a straight silicone joiner between the turbo and IC piping instead.
Actually works out to be similar price in the end anyway, just a little more hassle but becomes better off in the long run.
Going to get a new hose clamp as well to replace the one that I think is no good.
Will post back results tomorrow night ;)
Just f**ked around with hose clamps and shit just to see if I can have it running a bit nicer for tomorrows driving.
Started the car up, idling like f**kin' shit, hunting up and down, getting worse and worse and then stalling.
'f**k this' I think to myself, get in the car and just go for a wicked thrash.
Park back up again, idling like a f**kin' dream and not being gay on low throttle, WTF!
So see what happens tomorrow morning on the way to work! - Still going to replace the silicone 90 degree with stainless steel though.
What AFM are you running? It might have the dreaded bad solder joints on the board inside.
It's an RB25DET S2 AFM, I have a 300ZX AFM here ready to go in whenever I can get the car tuned/chipped.
Is it something that I can fix myself? Or if I open it up will it be easily spotted?
Cheers.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
