Hey peeps the other day i had a full 2.5" exhaust with a 4" cannon fitted to my na 34 anyhoos when driving at about 2000 rpm this fdup vibrating noise comes in and doesnt go till about 3000 is this normal as it rapes my ears cronically but it only seems to be on the inside of the car and it sounds normal outside also it sucks driving up hills coz i cant even hear my music or people in the car speak and it sounds madd as once u get past the noise any help or intuuition would be appreciated cheers jarrod.
https://www.sau.com.au/forums/topic/304891-new-exhaust/
  • Replies 40
if it was the gearbox it should've done it before the exhaust got fitted.
could possibly be that the exhaust is hitting the body though. might be worth getting under the car to see if it is sitting close to anything. or maybe have someone stand on the side of the road and go past them with it making the noise and they should be able to tell if it is exhaust noise or a rubbing noise
https://www.sau.com.au/forums/topic/304891-new-exhaust/#findComment-5047405
sounds like the typical rb NA drone that becomes very obvious with an aftermarket exhaust, mine will do it still, and ive got a 2.5 inch exhaust with a mid system 2in1 muffler/resonator plus a second resonator and a twin tip muffler
good news is that its easy cured by changing ur driving style, just drive in a gear lower then you normally would and let it rev up a bit (the idea being to keep it above that drony 2 or 2.5 - 3000 range) then get into 5th gear when your done accelerating - unless your in auto? then you might be stuck with it
https://www.sau.com.au/forums/topic/304891-new-exhaust/#findComment-5047489
theres a good write up somewhere on here about rb motors having a "raspy" metalic vibration or rattle sounding exhahust note at a certain rpm range but there nothing actually wrong, mine sounds a bit like this sometimes
https://www.sau.com.au/forums/topic/304891-new-exhaust/#findComment-5054987
I had that tinny crap sound ended up being that my stock nissan catalytic converter was stuffed and broken apart ... (catless and hollowed out cat's are bad for this resonance noise around the 3500- 3700 rpm area aswell )
So to fix that issue
My new exhaust system consists of the following on my R32 N/A RB20DE
Coby 6 into 2 into 1 with 2.5" outlet extractors
3" Catco Highflow catalytic converter
2.5" catback exhaust with single muffler and a canon muffler @ the rear ...
I had that issue really bad before I replaced my cat and found it to be blocked and a week later it broke apart into big chunks and allmost completely blocked up the exhaust flow ... so I pulled it all off and now fixed it all up and sounds really deep and has that good skyline note about it ...
https://www.sau.com.au/forums/topic/304891-new-exhaust/#findComment-5055228
twin cams make this rattle when you put a canon on it, the stock exhaust has a valve that opens and closes to stop this noise. Now you took it off and have a cannon it amplifies the rattle.
https://www.sau.com.au/forums/topic/304891-new-exhaust/#findComment-5062113
  • 4 weeks later...
I just got a 2.5" rear muffler and 3" tip. The sound is good, but the sound produced rapes my ears in my car too. It sounds fine outside though... I think it's because of the stock Nissan Catalytic Converter...
Any ideas?
https://www.sau.com.au/forums/topic/304891-new-exhaust/#findComment-5118977
Hi wht510,
It was just installed today... I think you're right about the rubber mounts... I think it could be the exhaust leaning into the bottom of the car causing the windows and the whole car to vibrate at certain RPM's.
Before I got this installed, I specifically asked for a nice tone but not enough to get defected. Also not vibrate the car. He suggested that a 2.5" rear muffler would do, and any sort of tip would be fine.
I will take it to another exhaust place to get it checked out tomorrow, Blitz Custom Exhaust (place I got it done) is closed tomorrow :D
https://www.sau.com.au/forums/topic/304891-new-exhaust/#findComment-5119082
I just went to Werribee Exhaust (99 Railway Ave, Werribee, VIC) and they have fixed the problem. The exhaust tip was too close to the bottom body vibrating the whole chassis. They let it down a few centimeters and it's all fixed now. The total cost to fix was $10.00. Muffler sounds nice in the car (windows up/down) and there's no more vibrations.
I hope this helps others with the same problem, especially to the OP.
https://www.sau.com.au/forums/topic/304891-new-exhaust/#findComment-5119479
  • 2 months later...
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
