Hey guys, only just recently i have had trouble with my engine misfiring bad. Its an R33 26 with big single in an R32 GTS-T, WOLF 3d, near brand new plugs gapped to .7, stock coils. It has never happened before until it was about 30deg the other night and usually after about 15mins of normal driving it starts.
I was driving along at about 4000 rpm in second and it started sounding like your typical boxer engine, and assumed an injector plug had come off as it's done it to me before. Checked all plugs and the problem stopped . . . maybe not. Started the car up, sounded good, drove along and it came back then disappeared, came back, disappeared etc. it even happens on idle sometimes (it's an extremely rapid misfire sounding like a machine gun haha)
Doesn't matter what gear or what rpm but gets really bad when you load the engine up or stay on constant throttle, and if you hit boost it will go away sometimes. The stock oil pressure gauge in the dash will get close to zero then jump to about 4, then just fall and rise as it pleases. Engine doesn't blow smoke and no oil in turbo inlet or exhaust.
I have checked all plugs and had to change number one as it looked fried (less than 2000km old).The rest still look new
Cut out each injector while car was running to see if there was no change on one. all good though
Changed fuel filter over in case it was blocked
I'm guessing i should just seal my coils with silicone and do a comp test but while i'm there should i be looking at anything else.
Any help appreciated
Edited by AE86 Spoontah
No i havent and there is no AFM. . .
but i have a theory after drivng home today. Another hot day and after 10 mins it started happening. Checked all injector plugs again an no change to engine noise to it's got to be the coil packs. Reason i'm thinking this is that there are hairline cracks in the coils and when under bonnet temps get too hot, the cracks expand and the spark jumps out. I'm sealing them up now so i'll see if that fixes the problem.
double check that coil plugs "click" when you attach it as it's happened before where loose connection causes intermittent misfiring
They all click apart from no.1 but you can't pull no.1 plug off unless you release it how you normally would
Sealed up coils with some quick cure high temp sealant but hasn't fixed the problem. It's gotta be electrical is it "pops" alot more now and the pops are louder like there is bulk fuel being ignited.
Could there be a problem with my ignitor?
Hi there, dunno what your problem is but seems like there are two which could be related. If you have sealed up your cracked coilpacks & the sealant has had sufficient time to completely cure without fixing problem or as you say making it worse I would be borrowing some known good coilpacks to substitute & check. Also I'm told that the factory Nissan oil pressure senders/gauges on Skylines are notoriously dodgy but you could also have bad electrical earthing causing your combined problem.
My 2c
Cheers GW
My 2c
Cheers GW
I might have to borrow my mates Splitfires and see if that helps. I heard to that the factory gauges shit at the best of times
too.
Put mates Splitfire's in and worked for about 10mins and the problem came back again so it's not the coils. Put my standard coils back in, sprayed coil pack module with contact cleaner and kept the vally cover off this time and the problem didn't come back after 10 mins, so i gave it a boot and it did it abit on boost. Maybe the coil pack module is getting too hot? Any one got a CPM i can borrow in Perth to test for 5 mins? Cheers
Found that the problem was the ignitor was getting too much heat soak in the hot weather so i relocated it next to the brake booster and have no problems with misfiring even on a 40 degree day. Crisis averted haha
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
