LEANBAC Posted January 22, 2010 Share Posted January 22, 2010 (edited) ok so a brother is getting a HDTV!!!!! dont know much about what i need but i sure.... i need a better antenna then the indoor one ive used since captain cook 1. so been looking on the net and the info im getting is that hills antennas are preety good... which one i need pfffft dont have a FARKING clue 2. does anyone know or do TV antenna insulations?.... like super cheap? im in S/E suburbs Edited January 22, 2010 by LEANBAC Link to comment https://www.sau.com.au/forums/topic/305064-dtv-antennas-and-insulation/ Share on other sites More sharing options...
R31Nismoid Posted January 22, 2010 Share Posted January 22, 2010 Any Antenna will be fine really. It needs to be setup correctly, that is your issue. You'll need to get a professional out to install/setup. Link to comment https://www.sau.com.au/forums/topic/305064-dtv-antennas-and-insulation/#findComment-5049711 Share on other sites More sharing options...
W0rp3D Posted January 22, 2010 Share Posted January 22, 2010 i have digital hd and im running off an internal aerial, if the picture quality is good with the one you have then there is no need to change it, no matter how much ppl tell you that you need a digital antenna, there full of shit. My reception was not the best on a couple of channels so i got a signal booster from jaycar, cost $30-40 and was a lot easier and cheaper than having an outside antenna installed. Link to comment https://www.sau.com.au/forums/topic/305064-dtv-antennas-and-insulation/#findComment-5050238 Share on other sites More sharing options...
some_cs_student Posted January 23, 2010 Share Posted January 23, 2010 Sometimes you will need to replace your old analog antenna with a better one for digital, we have 2 antennas, and had to replace 1 to get reception working properly. The connectors used are important too. But you can still get away with an internal antenna, I had rabbit ears ($15) working, they just looked a bit ridiculous been masking taped next to the window (the only place it could get good reception) and they were hard to tune. Link to comment https://www.sau.com.au/forums/topic/305064-dtv-antennas-and-insulation/#findComment-5051439 Share on other sites More sharing options...
blind_elk Posted January 23, 2010 Share Posted January 23, 2010 I used the same aerial that was in the house when I moved in 15 years ago, and it worked fine on the HDTV. Only change I made was to replace the old-school ribbon cable with a good quality coax cable. As luck would have it, I have a "spare" aerial if you (or anyone) is interested. Link to comment https://www.sau.com.au/forums/topic/305064-dtv-antennas-and-insulation/#findComment-5051449 Share on other sites More sharing options...
