hey all,
well i finally got my R32 gtst, although i want to make the exhaust legal by putting a high flow resonator on it.....its currently at 120db and want it under 90db. who makes some good decent priced high flow resonators that u guys know of?? prefrebally in the SE area of melb closer to Glen waverely the better.
Also the car has been broken into at one point and the locks are a bit buggered up, who sells and installs locks for the R32 also in the same area???
its also got a really loud fluttereing BOV, think its stock one not sure haven't had a good look yet, wots the process of making it a plumb back???
hope u guys and gals can help. ASAP!! cheers!!!
https://www.sau.com.au/forums/topic/30509-help-needed-locks-exhuast-bov/
i've had a look and it is a stock plumb back, but because its got higher boost running and a POD i think thats the reason its fluttereing so much? wot u guys reckon? would the WOLF3D have anything to do with it??
would putting a stock airbox and lowering the boost decrease some of the noise??
I think Before you go about "modding" your car I think you need to decide what you want from it in the long run, Becuase doing things twice can become a real costly affair,
Now a fluttering blowoff? what you mean exactly is there a "chhh"
sortoff sound aswell as the fluttering or is there just only flutter
because if ther eis only a flutter the previous owner has blocked the plumb back to the airinlet forcing the air to be thrown back to atmo through the turbine this is generally not very good for the turbo.
yeah more a sound as when i back off it goes chhh chhh chhh chhh chhh ch ch ch pretty quick but with gaps inbetween, not the psst from a BOV, as i said in last post i think, i've had a look and its running the blumb back and the noise seems to be coming more from the POD area. not the blumb back thingy
Yep it sounds like the prev owner has blocked the plumb line on your intake plenum undo the BOV and see if they have put in a spacer plate to block it up. if not they blocked it up in the line that runs to the turbo inlet (assuming this is the STOCK BOV)
hope this makes sense to you
The BOV located on top of the INLET PLENUM is held in by 2 bolts undo them and it will lift right off.
Good luck.
well PRO_32, thanks heaps, u were right!! i pulled off the bov and there was a plate blockin the hole. ripped it off, sealed it with some silicon and bolted it back on, now all i get is one swoosh of air gushing out. i'm guessing thats how the plumb back should sound. Thou will this now stuff up the fuel maps on the WOLF EMS?
Mufflers Now in Oakleigh [1611 Dandenong Road, near FTG road] and talk to Matt. Phone is 9563-1166 Apparently these guys do a swirl flow resonator that keeps the flow and cuts the noise well. GO THE 4 DOOR!!!
thanks Autotrust, thou part of the nissansilvia.com group buy i got a good deal on a bigger muffler today. i had a straight thru one on and at same time i realised i had a stock cat on the 3" piping, so i got the bigger slightly more buffled muffler put on and gonna get a larger high flow cat on soon. so in long run will be less restrictive and still legal cos i'm just under 90db!!! And yeah go the 4 door!!
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
