Iv had my Skyline for a few months now and since owning have noticed the engine feels rough between 2500-4000rpm. It sort of feels like it is out of balance or something. Just wandering if this is normal for the RB25 or do i have problems. Car runs perfect besides this and its just got me a bit worried. Cheers
Being the paranoid type, i got a 100k service done on mine not long after i got it.
Go to somewhere with at good rep like Trojan, ESP or Autotech that actually work on skylines; not just some guy who thinks that all cars are the same.
They will be able to sort out your problems and will actually know what they are talking about.
Just my 2.2c (inc GST)
Well all bolts are tight. Donnan i would take the car somewhere like that to get checked but i really dont have the cash at the moment. The car has 92,000kms on it so will have to take it somewhere in the next year to get the 100,000 service anyway. Hopefully its nothing major and will last till then.
Sounds like it could be a faulty CAS (Crank Angle Sensor)... I had the same problem with my RB25
To check if it is the CAS get someone with an identical RB motor to lend you their sensor, plug it in and if it fixes the miss-fire or rough revs then order one from Just Jap or another Japanese wrecker (dont get one from Nissan unless you want to pay through the @ss for it).
Start by checking the CAS, then if thats not it, move on to coil packs or ignitor.
(By the way - the CAS is the big round metal thing held in by 3 bolts on the front of the motor.)
Let us know how you go. :(
Hmmm ok any volunteers want to lend me there CAS so i can check to see if this is the problem. Or is there a way to test it with a multimeter or something, also if it was the CAS would it come up as a fault code because the ECU says no fault recorded?
Is there no-one kind enough to lend a fellow Skyliner a hand when they're in a tight spot??
I'm happy to lend you mine, but it comes with a catch... If it breaks while it's on your engine, you buy me a new one. :P
OK?
I'm happy to lend you mine, but it comes with a catch... If it breaks while it's on your engine, you buy me a new one. :)
OK?
After speaking with a professional about this, I'm afraid I have to withdraw my offer... There are too many variables with your problem :ermm:
Speak to Angelo at Trojan Motorsport about getting a working second hand CAS (they have a lot of spares on the shelf) = 6242 6277
Tell them that Mick from Federal sent you :D
After speaking with a professional about this, I'm afraid I have to withdraw my offer... There are too many variables with your problem :(
Tell them that Mick from Federal sent you :(
Hey mate thanks for your help and advise I will try and bring the car past there in the next 2 weeks, but with work at the moment its hard to bring it there during the day. The more i try to work out what it is myself the more i think it might not be the engine, its almost like the flywheel is out of balance or something :worship:
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
