Heya.
My cefiro's speedo stopped working a few days ago and of course my HICAS light came on aswell. This afternoon i got underneath and removed the speedo cable and driven gear from the box and it all appears to be in working condition. However when i spin the gear with my fingers the speedo dosn't move which it should, in theory (as far as i understand).
Can i safeley assume the cable has broken somewhere and replace it?
And if so, how do I got about this?
HELP!
Thanks!
Adz
https://www.sau.com.au/forums/topic/305453-ceffie-speedo-dramas/
No mods here to delete those 5000 posts you made, haha.
Yeah, sounds like the cable is broken somewhere in the line...did you try turning it from the other end?
Replacing it isnt as daunting as it first seems...the cable goes through the firewall right near the clutch master cylinder / steering collum openings. Disconnect the cable from the cluster and the box and unbolt that plate, take it all out and put a new one in. They're pretty cheap from JustJap/Sliding Performance/Nengun, etc.
It cost me about $90 to get a new cable from Nissan and arrived in 2 days. It's worth getting brand new though.
Mine was broken where it joins at the cluster too.
  • 1 month later...
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
