guys just bought a turboX boost controller,hooked it up and have played with it for hours!!! and the loweset i can get it going it is 13 psi,with spikes up to a 15! car is a r32 gtst full 3 inch, high flow cat , pod,bov,why is it so high and is this safe?
cheers
have you got it setup right ?:S
cause we use turbosmart bleedvalve an we can run what ever boost we want ?
(r33 gtst)
spikes on a bleedvalves are common. their not to good for holding boost either.
have you got a pic of how its setup ?
Here is a pic (attached) of how it is setup. From the picture you can see that the bottom hose goes to the wastegate whilst the hose on the left goes down and to the turbo. It was setup as the instructions said and is set up the same as on my brother's 180. The instructions say to never let the fine adjusting screw more then 2 turns from fully closed otherwise lag will occur. If I set it to 2 or more turns then it spikes past 15psi. So it is now set at less then 2 turns. The coarse adjusting valve is also set as low as it can go. I'm not real sure what the problem is only thing I can think of is that the hoses have some kind of problem ?
u hook 1 to the wastegate line on the turbo and the other to a pressure line on the intake (cooler pipe is easiest), thats how it reads the 2 different pressures
Thats right :thumbsup:
it should look somthing like this. one goes to the actuator and the other hose coming off the bleedvalve should go to the intercooler pipe :(
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
