Heyyyyy guys im all new to this, a week ago i have just brought an imported r34 skyline from victoria though it got approval over there when i took it to regency ( motor identification place ) they failed the check due to some parts tht i need to either replace or take off so i was really hoping if anyone from adelaide would be able to hlp me if they have standard parts if i could borrow them for a couple hours just to get it registered it would mean alot since im really stuck thank guys
the parts i need to change are:
i need standard tyres for an r34 as mine art the right sizes
i need standard suspension as mines automatic coil overs
and also a standard r34 exhuast as at the moment i have a hks exhaust on it
though i also got done for having a turbo timer and blow off valve i can just take those off
if anyones i little hesident on leding the parts i can leave a deposit in your hands jst until i get it registered or i can leave my parts with you :(
welcome to the forum Keith....have you tried contacting like an import wrecker like JIS....or an import yard???
sorry i dont have R34 stuff otherwise i would lend it to you mate.....as for your exhaust just get a baffle plate made up mate
Hi Keith, welcome to the site.
FYI there already is a thread of items that are 'wanted to borrow' and plenty of people have listed parts in there they are willing to lend.
http://www.skylinesaustralia.com/forums/Wa...ow-t220735.html
If you have a 4 door R34 I have a set of stock suspension you can hire.
PM Luke_ENR34, he has a stock 4 door exhaust, and last I knew had a set or R34 stockies.
But check the thread I listed above and start PMing. In my opinion a normal hire fee for these sort of things is $50 an item, but everyone has a different opinion - some free, some much more.
heyy mate thanks heaps umm do u no if the suspension on the 4 door wud b the same as on the two door?
what do u mean by baffle plate mate?
a piece of metal that goes in the exhaust to disrupt the flow of air - makes it quieter at the cost of airflow
-D
aaaak ;) na i gota replace the whole thing jst coz wen i got the car it had already been complied to aus standards but the guy i then brought the car frm put them bak on the car but i rkn iv found someone thatll lend me theres jst for a couple hours :) cheers anyway mate by any chance u wudnt no anyone tht has stock suspen do ya?
cheers
I am not sure if the 4 door suspension is the same as 2 door mate.
ill find out tmro morin :down:
cud i lend it off u if its the same mate?
also if anythn did u want anythn for lettn me lend it for a couple hours?
cheers hpz mate
strange that they did that at the vehicle id inspection... when i brough my 33 in from victoria it would have failed a proper regency inspection but they didnt seem to care at the id place...
Edited by GoAhead
well they didnt but they sussed the turbo timer then they told me bout making it 100% standard as the compliance says it it then to bring it bak for another id check jst so it matches so they wrote a list dwn of wat i gota do iv practiali got everythn except standrd suspension so if anyone can help with tht it wd b the biggest help anddd the 4 dr suspen is the same on the 2 :down:
hey Keith please back off on the abbreviated typing - this is not a mobile phone, and you are not texting. It makes it VERY hard to read what you are talking about and makes you look like a tool. Just saying ....
sorry mate
so do you still have the suspension? if so could i borrow it for a couple hours so i can go through an id inspection check?
Yeah you can borrow the suspension for the price of a carton of Coronas :down:
Good luck on only needing it for 2 hours though - will take more than an hour to change the suspension over each time.
It is just sitting in my garage, so you can have it for a week if you want. I am pretty sure the R34 coupe and 4 door is physically the same suspension.
Only thing I don't have are the pillow/camber tops, so you have to use the ones on your current suspension.
thanks heaps mate yeh thats all good could i get a contact number or something so i could give you a call to organise it all?
2 door and 4 door suspension is the same. I swaped 2 door suspension into my 4 door no dramas. At the end of the week ill have standard GTT rims and tyres to lend out as well as stock suspension. R34 stuff is hard to find sometimes!
hey guys im after some standard r34 tyres to borrow to get through regency with could anyone please help?
thankyou
there 2605 tyre i need all four
im not sure why your tyres arent the right size? 2605 isnt a tyre size, if it is on the standard rim its most likely a 225/45/17 , 225 being the width in mm, 45 being the size of the sidewall of the tyre in mm, and 17 being the size rim it fits in inches.
    • Hello Liam - HA - somewhere in flies - possibly I have an update, but I have been so busy, projects have taken a back seat to getting business back on track.  I will let you know the outcome, but I think I am going to go for the 8HP,  CHEERS.  ELVIS
    • Thanks Joshuaho96, yes - as someone else also suggested, the 8HP seems the 'smart choice' - HA - and ZERO to do with cost, but I am sure 8 speeds will be better than 6 speeds - HA - maybe.  I will purchase a new 8HP,  Thanks.  ELVIS.
    • Nobody said anything about getting a "...cheap Falcon box..."- it was JUST a question about a specific transmission.  And YOU may have a problem with not enough $ - HA - I do NOT - so please keep your comments like you are some financial guru to yourself.  BUT - much appreciated re the cost of a new 8HP and I twill probably be the way I go.  Thanks.  ELVIS.
    • Most people I know in the BMW world are swapping 6HPs for 8HPs. The 6HP has a big issue with one of the clutch drum bushings wearing out shockingly early which leads to them going into limp mode going into 5th/6th gear as the oil pressure loss from the worn bushing causes clutch slip. Even with the adaptations in shifting the TCU can't bump line pressure enough to keep the clutches from slipping and burning. I've personally looked at a 335d with 6HP28 with one owner and ~90k miles on it and the transmission adaptations were way out of spec and even though it nominally drove ok I'm confident it would have needed a full rebuild sooner than later. Other than that they're fine, but the 8HP doesn't really have weird issues like this to my knowledge and they're in everything these days so pulling them out of crashed cars isn't too hard.
    • There is an ABS pump and a few solenoids. You could trigger the front/rear solenoids with a pressure bleeder attached with a Consult 2.
