  • Replies 211
Posted Images
you dont get much of a choice with the vorks unfortunatly, as they are a full racing rim, they only make them in special racing sizes... for ideal racing conditions.. you want 17" rims.
cool i see 17 how muc you tink iwould sete back with out tryes?
kk something like that what inch 16.17.18?
smaller is better?
personally i would probably want to go with maybe 14's x 15.. that way it will be able to give you a heap more traction and maybe start running 10's...
or maybe even 22" solid chromies to add a bit more weight to the rims to minimize wheel spin caused from the super stock turbo
vorks arent cheap man... but you get what you pay for.
ive seen them for around $890 a set (of 4) with really good race spec tyres designed especially to be used in conjunction with those wheels.
cool my barrier is bout 1.7 so thats cool iv seen some skyline what are maroon and white rims look ok
yeah maroon and white looks good... keep in mind though, if you get white rims, you'll have to get your car log booked and it will need to meet alot more requirements set by ANDRA (the australian drag racing association), it will need a proper approved roll cage and parachute...
so your probs best to just get silver or bronze wheels... save the hassle.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
