If you take the time to do some searching many if not all of the questions you ask have already been asked and answered so assuming you do a search of SAU here is the one of the best links that should fix your issue very cheaply. If you take the time to add to these threads it remains as a quality database for the next person with the same issue.
http://www.skylinesaustralia.com/forums/in...t&p=3587533
https://www.sau.com.au/forums/topic/305793-coilpacks/#findComment-5058966
Mate I've got Splitfire packs in mine. When i was looking at doing the swap i talked to a couple of workshops and alot recomended superspark as a cheaper alternative to the splitfires. Haven't heard much about the yellow jackets, and also the JJR ones Just Jap sell so i would stear clear. unless someone can recomend them. but unless they have been in a car for a couple of years you cant realy give a good opinion.
https://www.sau.com.au/forums/topic/305793-coilpacks/#findComment-5059915
i had jjr coilpacks in my 32
but it came with them so i dont know any difference from the stock ones
i've heard good things about the yellow jacket ones so i'd go with those as a cheap alternative
https://www.sau.com.au/forums/topic/305793-coilpacks/#findComment-5060894
I have only heard good things about yellow jackets too so i reckon i will go for them
https://www.sau.com.au/forums/topic/305793-coilpacks/#findComment-5061322
Anybody got a set for sale? I have looked at yellow jackets, supersparks and spitfires but i am pretty broke
Try wolverines method and if that isnt effective try second hand factory items.
http://www.skylinesaustralia.com/forums/R3...ts-t305560.html
Mine were pretty rooted after 10+ years of use and I opted for the proven super direct ignition system and didnt stuff around with other inferior brands.
https://www.sau.com.au/forums/topic/305793-coilpacks/#findComment-5062615
Thats pretty much why i went for the Splitfire straight away. I know now that the will last the rest of the life of the car. No matter what mods.
https://www.sau.com.au/forums/topic/305793-coilpacks/#findComment-5065525
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
