  • Replies 90
these items still available:
- r34 gtr powerfc with hand controller $950
- r34 gtt Bride drivers side rail for Bride bucket seats (e.g. Zeta II, III, Guardis III) $200
- r34 gtr boot lid silver colour (no wing) $100
- r33 gtst rear rotors and calipers $300
- s14a genuine ganador aero mirrors (painted pearl white) $390
- Racepace 3.5" rear muffler, super high flow but quiet (was used on my 360kw atw R34) $650
GTTR34 Do you still have the boot lid?
quote "r34 gtr boot lid with tail light, silver colour (holes where wing has been removed) $100"
Need one with no rust as my skyline boot lid as rust under the spoiler.
Where abouts are you so I can come get it?
Thanks mate.
bump
- s14a rear tail lights + center garnish $180
- Racepace 3.5" rear muffler, super high flow but quiet (was used on my 360kw atw R34) $500
- r34 gtt Bride drivers side rail for Bride bucket seats (e.g. Zeta II, III, Guardis III) $180
- r33 gtst rear rotors and calipers $250
- s14a genuine ganador aero mirrors (painted pearl white) $370
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
