Random query,
Any of the local boys know how hard it is to convert the Series 1 to Series 3 xenon headlights? Have asked Ben but no reply yet. Wouldnt mind looking into it down the track.....
Hows the new job goin' Phil?
  • Replies 1k
Posted Images
Haha yeah. Really want this bike going and i decided against doing a dodgy on the bonnet. So once the bikes running and i have another mode of transport im going to put the 32 on stands and start getting serious.
Random query,
Requires modifying the brackets a little bit, that's all. I actually had a brand new set that I sold a few months back. They looked very sexy :)
Pretty flat out with all the changes in the shop but yeah going good.
No changes to middle grille at all? or wiring?
if it's that simple, I will definitely look into it. As much as I like my current headlights, proper Xenon S3's would work better.
Much like a certain Carbon spoiler blade sitting on a bed in townsville :ph34r:
also, good to hear about the shop being busy. hopefully things change and the rep actually gets picked up :)
Edited by Force Fed
Hey Phil
was searching through some old threads and saw you involved in a bonnet strut group buy. And then I thought I'd seen a photo of your car with bonnet struts
Was I paying attention or dreaming lol?
I want to get some for mine. Have a rough idea of what I need to do, just wondering if you found a good car to steal the struts off or if you bought a kit etc.
I can use the lower supports from a VN-VS commodore as far as I know, but Im gonna need 4 of these. If they dont fit on the bonnet mounts then I can do some fab work to make them fit
but anyway, just wanted to see if you had any pointers. And if you in fact dont have any on your car, then sorry for wasting your time with this post :P
Hey Phil
Nah I don't have any. I was looking into it however the only way that I could see to do it was to drill new holes into the gaurds to mount the struts, which is something I didn't want to do.
Alright sweet. Yeah hit me up when u get the shockproof in. Are you getting light?
Yeah lightweight.
Can't edit my post for some reason....... so I'll make a new one.
went to a mates today who bought a bonnet strut kit for his 180sx, Link:
Ebay: 240sx Strut Kit
Looks like it'll fit a Skyline pretty easy, I've ordered one so will let you know if it does, if your still interested in bonnet struts
See how you go. I measured one up on the factory hole in the guard and it just wasn't going to work in that location, would have fouled on the bonnet as it was closing.
That's why they only make the Tein/Top Secret kits to suit a GTR bonnet - different hole location. Also due to our bonnets being so heavy I also think the factory bolt hole location wouldn't give enough strength to hold our bonnet up.
But let me know what you find.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
