  • Replies 1k
Posted Images
You talking about my car? Going down a steep drive way that won't work to well lol.
Will take $1300 for the gearbox and clutch if any one wants it. Pretty sure it will sell this week at that price so hit me up!
umm get a few ppl around the car and it will work fine.... u still living in the same place u always been ?? if so that driveway isnt that steep teehee.gif
The car is there but I don't live there any more - that's my parents place.
Nick buy my wheels you poof.
Speaking of selling wheels. I need to get rid of some 17" factory R34 GT-T wheels.
They have a few scratches and some worn down but probably usable tyres. $400 bucks pick up from the city.
yeah goin widebody robbo. should come up good.... no motor isnt in yet mate. got loootttttssssss to do before i put it in. seam welded it last weekend but. just gonna clean it up a bit then paint it again. then i might chuck it in lol
