Hey Guys i need a little info and a turbo (maybe)
1st things first, does anyone have a good Vg30 turbo for sale? my is leaking oil into the front cover and wont pass its road worthy in vic, and or is it cheaper to rebuild? or does someone have something bigger that will bolt in place with no mods? im thinking about cost here really.. i need something cheap even if someone has a good vg30 nugget and i can use my housings..
Cheers for help with that.
and second can someone tell me more about fitting a gts25t gear box to an fj20et skyline? mainly do i need a different clutch and flywheel? iv heard speak of it being almost a direct fit if you remove some one or two of the engine/box locator studs???
Cheers for you help as always guys
Marc
https://www.sau.com.au/forums/topic/306134-a-couple-of-things/
I have a VG30 unit, but there is a chip/4x5mm piece missing on one of the compressor wheel blades.
you may be able to make a good one out of the two, but it will still need balancing,
a full rebuLid is around $500, depending on what you are after.
Hypergear is a workshop in Vic, they do replacements, rebuilds, and new units. the Tr43 is especially a good unit, may be too big fot a 2 litre though.
Cheers guys..
i dont think the turbo with the chip will be any good as that still means a rebuild really?? tell me more about that second turbo? the upgaded one? my car is a 2.2 stroker with with forged pistons etc i think it should be ok to go bigger??....
as for the oil return from the tappet cover this might be the issue?? ill check that out! however the guys at nisco said to me they thought it was a turbo leak?
thanks
The bottom line is cost.
The cheapest option is to rebuild what you have, it seems to be a fairly good match to the engine.
If you were looking at modifying your setup, there are some really good new turbos out there. Ghostrider has more info on this (he is building the FJ track only car)
And I have an HR32 GTSt RB20DET box with a modified bellhousing, waiting in the wings for when the FJ box gives up the ghost under the strain of about 400+HP. And an HR31 GTSt box as another backup.
My sources tell me I wont be able to break it and it's heaps cheaper than either the Z32 masTers is using or your GTS25t box your talking about.
From what I'm told, you will have to use an FJ20 bellhousing and mate the new box to that.
As for turbo's, VG30's are available in good nick for about $300 on ebay, your just going to have to wait till one turns up.
Cheers, D
Hey Dennis, From experience the RB20 boxes give up around 350-400 rwhp. The vg box is around 1200, and the RB25 box from 1400-2000 depending what car it's from. You might be better of sellin the 2 and just buying a vg box? Seems to be a huge demand for rb20 boxes over here as they are pretty rare, and the cost of converting a 32 to an rb25 box is quite high for the average gtst owner
In a track only car that driven once or twice a month the R32 box should last a while, but if it's a daily or driven in spirit often I'd just go the VG off the bat. Interestingly enough a close friends HR31 box shat itself at 250rwhp.
The HR31 boxes only have the single ring synchros & therefore are not as strong as the HR32.
If one could be acquired the Nissan 280ZX box was as good as we can get too.
Cheers, D
Just bought a Z32 turbo box, so I guess I'll be right for gearboxes for some time.
I'm going to investigate putting the Z32 box behind the L28 in the PNV as I think the torque I'm expecting will destroy the stumpy L20 boxes far to easily.
Cheers, D
Dead easy swap, elongate a couple holes in the bellhousing and it fits straight up, I have done a few for friends before. However the RB25 box has a larger output shaft so you will need a custom tailshaft. All though none of these went in R30's so I dont know where the shifter comes out in comparison to standard
Edited by DR JOSH
Cheers, D
z32 box the goods, cheaper than 25 and stronger i swear i did a searcch on google and came across a guy in the states that does a kit to put a z32 behind a l type mota
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
