Hi guys i been searching for a while now and couldnt get a straight answer.
Im currently building an rb30det with a rb25det vvt head with PROcams, I will be using tomei cam gears with the VVT removed. Do i still need an external oil supply to the front of the head for the cam journal or is it only used for vvt purposes?
Any help would be appreciated.
https://www.sau.com.au/forums/topic/306143-procams-in-rb2530/
Front feed in the head is for VVT. If retaining VVT there are mods you can make in the gallery, otherwise run an external feed as per the RB30DET guide.
If deleting VVT there is more than adequate oil supply to the front cam journals. You can also remove the solenoid and install a bung to simplify things.
Be sure to check the lift specs in Pro Cams - beyond 9mm in a RB25 head will probably require machining to give adequate clearance and avoid coil bind on the valve springs. If unsure you should consult with a head specialist and get things measured on the bench.
Unless for extreme use, external drain is over-rated and misunderstood IMO.
Better value and results if the time and effort is spent drilling out the internal drainbacks in the head and block.
Otherwise, yep, use a bung where the solenoid used to reside (make sure it is the correct type to seal), and have the feed hole welded or grub screwed as per the guide.
fair enough. atleast its clear now. I have the head next to me now all apart and i can see that the vvt cam journal has 2 holes in it. One of them must me a constant oil supply from somewhere and the other is a supply from the vvt solenoid yea? The heads going on an rb34 stroker bottom end and there isnt must money spared on this setup so i wanna do it right without any troubles.
  • 4 months later...
  • 1 month later...
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
