Rb25 Conversion Sitting High
So the issue only occurs when indicating right, AND you're missing a bulb in it. Normally on old flasher relays, when a bulb blows, they start to flash quicker. If you have potentially another short, or a couple of lower resistance bulbs, the constant noise you might be hearing is actually the flasher relay dropping in and out really quickly. I suspect if you get your front indicator wired in, your symptoms will change...
Good evening SAU team , just a quick update on the 400r , just had the guys Lush Auto Spa (https://lushautospa.com.au/) do full paint correction and ceramic coating(Exterior and Interior) pictures look great , I'll be picking it up tomorrow. Highly recommend these guys if you are looking at brining back the since back to your vehicle.
Yeah definitely planing on updating the ecu down the line. Wanted to enjoy the car and save up some more before I start making changes
