Hello
Does anyone know anyone who are good with driveways? I'm scraping my undercarriage as I go up my driveway into the garage as I'm on a hill
The top layer are puzzle bricks, and underneanth is cheap clay that can easily be removed. I'm kinda arsed doing it myself, so if anyone here specialises in this please let me know
I just need that particular section lowered by about an inch
Quite an easy job, but if you have the equipment it'll probably take you less than an hour, rather than me using a gardening spade and going at it.
https://www.sau.com.au/forums/topic/306561-driveway-people/
dont bother with a concretor/driveway person. hire a labourer for a day (around $150) and get them to do it. a concretor/driveway guy will charge you for more than 1 labourer, their own wages, profit as well as try talk you into concreting the whole thing.
https://www.sau.com.au/forums/topic/306561-driveway-people/#findComment-5067596
i just concreted the front of my driveway because my street has that gay ass drive up gutters that skylines and other exotics can't seem to drive over, ive already cracked one front bar on the skyline from it, and i'm not risking it on the new car. just used the old concrete tools from the garage, bought concrete and concrete binder. Did it this morning, ive watered it twice, should be strong enough not to crumble anytime soon,
Trying to fix already laid pavers is a much harder job though, try it yourself, if that fails get a pro in afterwards.....
https://www.sau.com.au/forums/topic/306561-driveway-people/#findComment-5069351
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
