you wont get a private drift day for 220 bucks wayne, ita a max of 10 cars
its round the 350 mark
This expensive... Hmmm... Still worth it for the amount of track time you get Vs. a prac night.
20 cars on a drift day would be perfect, 2 groups of 10, rotating and not unbelivably expensive
^ only thing I'm iffy about with a private day is stacking my car or it breaking something early in the day (both highly likely :()
Paying $130ish bucks to hit the track and only getting half a session is pretty frustrating, paying almost 3 times that and getting a half hour or so of skids would piss me right the fuck off.
If I was confident in my shitbox lasting I'd be so down for private days but rocking normal pracs is providing plenty of fun/lols for the time being.
Very valid point, thats what I was worried about at drift school. First outting in the car had no idea how it would go and going out for 30 minutes and then having to put it on the trailer would have pissed me off so much lol
No skid pan work jess.
Chad, Craig, Andrew... who is heading out for a skid aug 14? any other first timers coming out for some fun?
i would head up but im going to melb to party
sept skids get on it
tandemsss
melb sounds fun :).
Tandems in sept it is mang!
bar tabs are even better ;D
<3 engagement parties haha
yep, im gonna be out there again, so keen to test the hydro :(
ill be out in sept to test my hydro out :D
Them ones look decent Mitch but I'd feel unco with the upright hydro lol. and to make it legal you must maintain a mechanical handbrake i.e. like what I am running.
only one bolt stopping it from being horizontal :)
and ill be keeping the stock handbrake , just gotta confirm it with vehicle standards :(
those hyrdos can run vertical OR horizontal
correctomondo !
I got brand spankers. Would like a pair of 80ish %'ers just incase too.
i hate using 2nd hand tyres, the f**kers delam after 10 laps, then your in the pits changing wheels and then you loose track time etc. meanwhile the tyres are cheaper... you probably worse off in the loss of track time and the pain in the ass that the 2nd handies don't last f**k all unless you get a set that dont delam
i went through one set of brand new jin yu's at drift school and i wasnt exactly driving easy :)
deff will buy newies before skids again
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
