just did my gearbox oil change today and heck, might as well take a couple of pictures in case some of you guys are wondering how its being done.
before i continue, you have to bear in mind that ANY oil change can be a VERY dirty, messy and tiring job but think of the satisfaction and money saved. THat's what motivated me in the first place. I also felt that it would help me understand my car better :sly:
anyway... here goes... my FIRST gearbox oil change in my R32
I needed to get the car high up from the ground so that I will have plenty of room to move around. I thought of car jacks and found these steel ramps at cash converter for only $20!! Each of them holds a maximum weight of 850kg. It holds the car pretty high up off the ground and its great for future use in engine, diff oil change and brake flushing/bleeding as well as some underbody works.
PLEASE do remember to (1) handbrake, (2) get the car in gear and (3) chock the rear wheels of the car.
Recommended equipment:
Get a LONG wrench for that ALL-SO-IMPORTANT leverage(size 1/2 inch)
Get a pump and your new gearbox oil ready.
tools, torchlight, degreaser, rags, hose, vacuum cleaner :)
and NOW, the fun part begins....
when you are done with your warmups and body flexings... get under the car to the gearbox. There is a drain plug on the bottom centre of the gearbox, there is no way you can miss it.
It is IMPERATIVE that you undo the filler plug FIRST before the drain plug!! If you undo the drain plug first and got all the oil out and then realized that the filler plug is stuck... you can start building a display cabinet for your car :tool:
The drain plug is usually the harder of the 2 to undo... i had a bitch of a time trying to get it out... broke 1 wrench and decided to get the STRONGEST and THICKEST 1/2inch wrench i can find in Repco... the longer the leverage, the easier it is to undo the plug. Another recommendation i had was to undo both plugs just after a drive so that all compartments are still hot... but the downside of this is that you will have to be EXTREMELY careful of the cat, exhaust piping and the gearbox itself becos it will get freaking hot.
make sure you have at least a 5litres and above oil tray for the old oil once the plugs are undone.
when the old oil is draining from the gearbox, get to work on the 2 plugs.
https://www.sau.com.au/forums/topic/30665-r32-changing-gearbox-oil/
Clean them both, esp the drain plug. You might noticed some metal shavings from the magnetic part of the plug, get them off... its normal wear-and-tear from the gearbox. Run a single layer of plumbing tape around the threaded end of the plug (not necessarily but i did it anyway...
once all the old oil is drained, put the drain plug back. How tight you want it is ALL dependable on yourself... gearbox oil can last for a pretty long time and its usually recommended that you get it changed once every 2 years (dun quote me on that). If you screw it tightly with a vengence, then you will probably end up cursing yourself more then... anyway, i tighten it with a vengence... :)
the rest of the work is pretty straightforward... pump in the new oil (filler hole) till it starts overflowing from the filler hole. once that's done, screw the filler plug back on... again with a vengence.
and wala... you got new gearbox oil...
btw, i recommend that you get your driver seat covered like i did... once any stray oil gets onto the seats, the stain and smell stays on...
next project for me is diff oil change... wanted to do it today as well but going to read up more on the redline oil specs first...
hope this helps
cheers
glenn
if you are sliding under the car with your head towards the back of the car.. the filler plug will be on the left side of the gear. If you can find the drain plug, run your left hand (careful when hot) along the gearbox and you will find the squarish filler plug. It sticks out like a sore thumb and there's no way you can miss it.
ask for the redlineoil .. chk out www.redlineoil.com.au for the nearest retail outlet near you.
run a search thru this forum and you will find more info on it.
tranmission filter? that i am not so sure and dun wanna give you bogus advice. run a search and see what you can find. there's no filter on a manual, only a tiny magnet on the drain plug to attract all the stray metal shavings.
  • 1 year later...
i prefer to use the Motul range of oils...
they just released their LSD oil in 1L containers!! :D (instead of 10L drums)
Also can anybody confirm this:
gearbox in rb20 takes 2L, diff takes 1L??
engine - 300V Chrono (10w40 100% synthetic ester)
gearbox - Gear 300 (75w90 100% synthetic)
diff - Gear FF Competition
brakes - RBF600 (DOT4/600, 312 degree boiling point!)
  • 5 months later...
  • 2 months later...
  • 1 year later...
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
