Everyone thanks so far but I think you are all getting carried away....hehehe.
I was saying I'm thinking of fitting a aftermarket non atomspheric BOV. My stock is still holding boost. So iis there adjustment required to be made on the BOV? I have a return flow FMIC and cat back exhuast at the moment.
Cheers
Daniel
The simple answer is: if your Blow Off Valve has any adjustment mechanism on it then yes you can adjust the valve to suit whatever amount of pressure that you would like to release. The amount is dependant on what you want to do, so no-one else can answer that except you. A mechanic and/or tuner will help you in this respect after you have worked out what you want to do and why you are doing it.
Why are you thinking of putting a atmospheric Blow off valve? They are illegal and generally make a standard vehicle run erratically but they do sound fooly sik maaaayte. On a highly modified vehicle they have their place but add little to a basically stock engine.
If thats what you're after then go for it, remembering that the change will have consequences.
The type of intercooler won't make a difference unless you're also changing the position of the BOV. If you're just mounting it on the stock RB25 position then just make sure that it clears the bonnet and that you also remember to block off the return pipe from the stock BOV.
The type of exhaust that you have fitted will not make a difference to the type of BOV fitted.
Does that clear things up a little for you?
Hermit...
Cheers
Daniel
my opinion, forget about getting aftermarket BOVs even plumb-backs. the stock Nissan BOV can take alot of boost without leaking. Kier Wilson's own skyline had the stock BOV in it and he reckoned theres no way they'd leak so dont see the point of changing it if it doesnt make any difference at all unless you're looking at beyond 2 BAR or 28psi boost but then again it wont be a street car anymore if you run that much boost.
if you want induction noise, get a pod filter and be sure u get an airbox made up for the pod to avoid cops trying to sting you when they see the pod and it will also be shielded from engine heat. u'll get a bit of power out of pod filters too.
Thanks all for the advice. That was what my tot was also that it will make no diff on a stock motor even with just the exhuast and FMIC in place. Rather new to this turbo game (previous car tricked out twin cam civic).
Anyways was told by a work mate of mine who claims to drive a skyline before back when he was in the east. That I should have by BOV changed cos of this 2 simple things that I have done. Kind of suspected that he knew also next to SH*T cos he told me my HKS exhuast was useless no power cos it makes no sound (not loud). He said loud exhuast equals power. From there I started to feel that he already know nuts.
So that is why I came in here and asked you guys out there proper who are into our type of cars and now much more.
Cheers
Daniel
Get better friends :)
As R33_Nick mentioned before, getting a pod filter or even a high flowing filter for your stock airbox (such as the popular K&N filter) will give you a more efficient power source. If your exhaust is a cat-back only then getting a turbo back exhaust system with a high flowing catalytic converter will improve things even more. Most engines works better when they can breath better, on both the intake and exhaust sides. Some engines need restrictions but a RB25DET will be better with less restricting "breathing".
Since you already have a Front Mount Intercooler then you may as well spend the money that you were going to spend on the BOV on upgrading theinduction and exhaust side of things first.
After that, then you can start shovelling in money as your quest for more power, traction and handling etc etc grows.
Keep asking in here " There are no stupid questions, only those that are not asked".
Your friend was right though, the more noise from the exhaust the more power there is, just see those loud Hyundai Excel exhausts. Those cars are beasts, especially with the frangipani stickers on them!
Hermit...
This... Possibly the most accurate statement ever made on SAU.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
