Dont worry Rob, it'll go nicely with my chipped and paint star'd front bar
Black 33 made me think, I remember seeing a black one blue lights in the rear wheels recently, wouldnt happen to be one of you guys?
  • Replies 206
ah yeh my car is dead atm fuel pump died its at mechanics and wont be fixed till late this week or so but will have it back b4 13th yeh i did see it had blue lights in back pretty sure i got a chip in paint in my front bumper 2 pretty ugly if u see it up close haha like big buble that cracked dunno how it happened was there b4 i bought it not bad but
I'm ex-Wodonga and I've just bought an R32 GT-R. I'm thinking about coming up to show it off to some friends, might see you up there when I get it.
dam r32 gtr i want to see biggrin.gif you'll probally see me around im always driving around pointlessly
good as like tomorrow or tonight banana.gif haha hope by time u bring it down i got my new wheels my car is like full stock atm haha and now its in mechanic cause fuel pump died... didnt even start had to get towd post-69723-1267527166_thumb.jpg
Edited by timr32gts
Damn that sucks. I test-drove two, liked the first one better but the second had much nicer wheels, so the dealer is swapping them over for an extra $800. Not sure how long it will be before I get it, I was told two weeks and that was a week and a half ago, might need to check up on them and find out.
yeah that would be the best thing to do have u got the vin numbers or chassis number fastened if you havnt might be worth it gettin them checked out just 2 make sure ur not buyin anything dodgey
haha yeh when it did a vs commdore for a vl wagon and vl turbo stoped real slow next to me and took off haha........ but anyway got car back today its all good was only fuel pump which is good
Good to hear you got it going again >_<
Yeah 13th is ok with me.. So where we gunna meet now I guess is the last detail required??
Bowna/Pines/Diamond Park(Causeway)?? Got anywhere better??
Just bought my new bodykit like 20mins ago. so it will be good to show mine off stock before the new kit and respray
GTR Front bar 400R side and Trust rear bar.. Happy to stay with S2 rear wing ATM. Hope it looks as good in real life as it does in my head LMAO !!!!!!
dammmmn 400r front kit when i was looking for skyline i was gonna get 33 and wanted that front bumper haha but got 32 i like more in my opion blush.gif but dam should look good umm causeway has all that road work shit there so dunno can you get in there im not sure even tho drive that way each day to work haha but yeh diamond park would be a good spot want to confirm it as diamonpark is that good with everyone?
GTR front bro. The 400r Fronts are too low and fragile and shred fast on gutters ect.
DIAMOND PARK is an awesome choice.. we can meet under the tree's next to the RC track and its easy peasy to get there from wodonga side (or freeway) dont need to negotiate any roadworks at all.. Ok with everyone else?
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
