  • Replies 45
actually i had a guy do it for me, but there was nothing difficult about it. Just pull out the rectangular covers on the side, unscrew the first bolts you see inside and things just slide off so you can pull things apart from the inside (steering wheel, airbag harness etc). The airbag itself needs to be taken out slowly that's all.
I know I've been vague, sorry...I remember watching the guy do it, n i thought, I could've done that bit myself. The hard part is getting all the other crap out from inside, and reaching the bolt that the boss kit will eventually go onto.
hmmm make sure you pull the plastic rectangular cover off from underneath the steering wheel. Then undo the plug that you see under there, that will disconnect the airbag.
remove 2 side screws as covered by Nrage33, you will need a tamperproof T50 driver. If you can't get a tamperproof, use a screwdriver to break the "point" out of each of the bolts then use a normal T50. Everything will slide out then...
butthead , before u do it find the airbag fuse and take it out , if u cant find that disconect the battery and take care when handling the air bag always hold it away from ur head .
As wrxhoon said,,,,either remove the fuse or disconnected the battery. I would have you dis-connect the battery myself. After that you can do what you like with it. It will not explode without voltage and thats a FACT. It's an electronic exploding device that is as lame as with no voltage. You will have to get someone that knows Nissan's to reset the light after you re-install it though.
Neil.
So I can't just disconnect battery, remove standard nissan airbag steering wheel, replace with a different standard nissan airbag wheel (in much better condition) and plug the battery back in to find everything 100% ?
butthead ,
i'm not sure if u have to reset the airbag light after u reistall it as i havent removed one in a skyline before . i have done it in other cars though and it works without reseting it .neil have ever had a skyline wheel removed? ( airbag ).
always be very carefull with airbags even if they are disconected , u dont want to loose u r head .
I just took the 3 plastic covers off my wheel to take a closer look (woulda took some pics but parents borrowed my camera for the nite).
For the last 9-12mths my wheel makes a clunk sound everytime I turn it about 90-180 deg and then clunk again when I turn it back. I'm guessing something inside is loose and is just rolling around but after taking the covers off and looking inside I can't see anything that isn't joined to another part that could be loose. Also now over the last week it sounds like a spring or something is loose along with the clunk clunk sound and it sounds like the wheel is gonna fall to pieces in my hands 1 day when driving. I can get a 2nd hand good condition wheel and hopefully just straight swap it but if my current wheel just needs a bolt tightened etc then i'd much rather just tightened the bolt and get another 6mths out of the wheel (if the leather will hold up that long). Anyone got any ideas ?
From what I can see (with a torch) their is just 2 weird shaped bolts on either side and then I guess the wheel just slides off (??). Underneath I can see 2 different plugs. It looks like 1 is a cable plugging into a socket and the other is just to cables plugged directly into each other.
Which 1 of these 2 needs to be unplugged to de-activate the airbag?
benm:
have u ever taken a steering wheel out before ? once u take out the cover ( regardless were it has an airbag or not ) u have to undo the nut ( usualy around 19 - 21 mm) then u need a gear puller to pull it off ( its tapered so it will be very tight ) .when u reinstall it u have to put it in the same position as it was before otherwise when u go in a straight line the wheel will not be in centre position .this is the best way to do it . put the wheel in centre pos and the front wheels pointing straight then take the wheel off ,make sure u dont turn the shaft when taking the wheel off or while its off when u r ready to put it back u put it cenre pos again , put the nut on take it for a drive if its one tooth out pull out and turn one tooth .
when u take the cover off ( with the airbag )u'll see the wires u have to undo , airbag wires are usualy yellow .
make sure u take the fuse off or disconect the battery .
funkymonkey , yes ur right but remember when u r driving u r head is far away from the airbag and u can get a broken nose but thats the price u have to pay so u dont get seriously hurt or even die .
Just spoke to CRD in Silverwater and they told me to remove my standard nissan airbag wheel and replace it with a good condition standard nissan airbag wheel i will need a boss kit worth $150 and thats all they can supply (It's illegal for them to change airbag wheels).
I'm guessing Nissan will be the only workshop that can replace my wheel and if thats the case it will be cheaper for me to buy an aftermarket Momo wheel + Boss kit (illegal modification) and have that fitted than to just put another Nissan airbag wheel on.
Not happy Jan !!
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
