  • Replies 235
damn i envy you kye.....should be a good race to watch.....
Yeah, it's going to be pretty sick man!
Boys weekend away, so there will be plenty of drinks had. Wonder what the high pitched F1 engine will sound like while I'm hungover!?
Rosberg in the Mercedes fastest overnight on day 1 of the Jerez test. Mostly a wet day so times probably don't count for sh!t
totally agree, but the really crazy thing with even trying to relate teams times this year is fuel loads, the differance between a light load and a full load will be stupidly lagre!
For sure. Fuel economy is going to play a huge part in how they fare this year.
Thats why qualifying years ago was fkn brilliant with teams using different engine mapping alongside extra sticky rubber and of course very low fuel loads.
Enjoy Kye. The sound those things make is music to my ears any time of the day, being hungover wouldn't matter :P
I'll be sure to take photos and see if being hung over matters haha.
But I deffently agree, the sound is amazing!
spot on.....as there is no refueling it would be interesting to see how many teams limp it to the finish line in trying to squeeze more out of less fuel......but only the top 6 really will be making a charge for a race win......as most will be on same fuel loads it will all come down to how the car is chewing rubber and how good the driver is.....
quite exciting really
http://en.espnf1.com/f1/motorsport/story/8534.html
some very good news for a little team.....Sauber could well make the challenge for the title as well this season....i love this kids driving
I am personally very interested to see how Kobayashi will go this year.
Save a couple Rookie mistakes, he did very well in the couple of F1 races he competed in last year, possibly the best driver to come out of Japan in a very long time.
Japan needs some decent drivers. Anyone remember Taki Inoue and his constant mishaps (like managing to get hit by the frigging safety car when he was running with a fire extinguisher...)
I remember watching that race live when that happened, I pissed myself laughing because all season this dude had been stuffing up and this was icing on the cake
-D
Many of them poor drivers have come and gone. Guys like that were only in F1 because they had $$ or had someone else paying for their seat.
Makes me wonder how they even got their super license!!!
Yes generally Japan has never sent over the driver with the best talent rather the biggest budget.
Even when the only reason there's a Jap in the car in the first place is that a Japanese team/engine supplier, has insisted that they have a one of their countrymen in the (ahem) 'second' team car, they'd still pick for the size of the wallet & not the talent.
I have been watching F1 a long time, but never remember seeing this incident. Not going to forget it now either!
theres another one, where inoue was being towed back to the pits and the pace car ended up flipping him over...
nfi how it happened - i never saw the incident but inoue was one of those guys in his seasons, where you could watch and KNOW that he'd be spinning out or crashing sometime, its almost like watching AFL/NFL/Gridiron and having a brawl break out.
Bad for the sport but oh so a guilty pleasure to watch - like longhurst punching his team mate in the head on live tv
-D
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
