so after my boost gauge has been sitting on my desk collecting dust for a few months i decided i'd have a shot..
after about 5 hours googling, trolling forums etc etc i still cant work it out (i have no electrical knowledge at all) and im not paying someone $100+ for something that probably takes 30 mins to do.. (yes ive rung sooo many auto electricians, cheapest was $100/hr)
questions
1. seeing as i have 3 greddy gauges, can i tap the wires from that (ground, power etc?) The Greddy gauges have the same wiring as the "autogauge" boost gauge.
2. If im able to tap those wires, all i then need to do is tpiece the vacuum line, mount the gauge, thats it right?
apologies for yet another "boost gauge" thread :happy: I know nothing about wiring (im at the point where i need pictures of what i need to tap / wire up)
https://www.sau.com.au/forums/topic/307242-boost-gauge-install/
hey mate where are you located? if you have a greddy slim series you dont need to wire it in they use power off the exsisting gauges.. if your close to mt gravatt i'll give you a hand wiring it in if you want ... simple really hardest part is mounting it lol
im over in paddington / ashgrove area. I think mine are the slim series like the one attached except i only have water temp, oil temp, oil pressure. Not sure what you mean, i dont need to wire my gauge in it uses power off the existing gauges? (how does it get power without wiring in?) or do u mean is the boost gauge a Greddy slim series gauge?
did a mock install before i tried it
photo below, the 2 top bits (the wiring and the filter thing, i have no idea where the filter goes, and i think the wiring is just extra incase you want to have a warning light)
pic below is where one of my Greddy gauges is already wired up, black, red and white wire (this was my reason for the topic, can i tap those three wires?)
pic below is apparently the vacuum line (which runs into the black unit which is the stock boost sensor for the stock boost gauge which is right behind the drivers side strut tower)
anyone know if im on the right track?
Edited by defari
first pic.. those ms paint bits you added to ask questions.. even on 400% zoom i couldn't even make out what you wrote..
why don't you get power off the ciggy lighter or something inside your dash that uses power when the car is started.. that way your not taking lines all the way to the engine..
if you got a factory vacuum line.. are you still using the factory boost gauge? if not then use that instead of the line with your gauge.. if you are then just cut into it and install that tee (one you circled
ah ok its a auto gauge.. well its better if you run the 12V acc power off your stereo , earth it either near the fuse box the bolts that hold the bonnet opener , one connects to your illumination (dims itself at nite) , the other is constant 12V this can be used from your stereo , you can earth it using the steel caddy around the headunit ...
by the way just to let you know you shouldnt tap into the Greedy sensor wires as that will stuff your gauge reading .. thats mainly for the sensor to convert it from analog (vaccum) to digital pressure for the gauge to read...
why don't you mount the gauge.. hook up the +ve -ve etc wires that you know where they go.. then try bribe a workshop to hook up the last bit for cheap.. tht way you've done most of the work and they make a quick $$$ for little effort
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
