Have a bit of a question re compliance, is it illegal for the company doing the compliance to comply a car which has had an integral part of the car removed? say the abs module? Is it also illegal for said company to then pass the car as roadworthy? This would of been done a few years ago, under sevs.
https://www.sau.com.au/forums/topic/307406-compliancing-question/
The short answer is if it's not roadworthy and is passed as roadworthy, then yes that would be considered illegal, but also bear in mind that once the car has been driven away from the workshop, they can claim that you or someone else pulled it out. If the ABS light isn't on, there's a chance they may have simply overlooked it - I've seen a couple of cars come out of Japan with the ABS disconnected.
yeah pretty tough to go back a 'few years ago' and prove what was/was not on the car. I'm not sure having ABS removed makes a car un-roadworthy. particularly if it was say an R32 skyline which has variants that come with ABS and other variants that have no ABS. It's a bit of a foggy question. In short, I'd say yes it's illegal. But if you have plans of suing them, or getting some kind of compensation from them then I'd say the chances are slim. They will almost certainly argue that the car was complied with ABS installed and fully functioning and that someone else has removed it in the intervening years.
if you only just found out about it what makes you think the compliancer or importer knew about it? especially if its just the abs module, none of the big engine bay gear. Dont go pointing fingers just yet, roadworthy doesnt check for abs working, just a simple brake test, and theres no way that any agent in japan should be expected to make sure the abs in every car they purchase functions correctly, in fact that would be near impossible.
I had known it had been removed, I just didn't know it could possibly cause me issues.
And Yeah well considering the plugs for the abs were tucked into the guard, and there was heat wrap around the lines I think not. Pretty bloody obvious.
That including the fact the roadworthy passed the car with bald front tires, and the fact I needed to get all 4 rotors replaced two days later as the pads were worn down to the metal/bonding material (like they did that in a 300km roadtrip home.....) makes me think they took their time doing the roadworthy.....
Amongst other things, I later found out the car had 60000kms taken off of it from when it was for sale in japan. Now who exactly wound it back I don't know, but I wasn't really suprised when I found out either.
I highly doubt anything will come of this, just utterly pissed off with the dealer I bought the car off.
as far as the insurance implications go I would ring and anonymously ask your insurance company how they see it. maybe it can be noted on the policy that the car doesn't have ABS or some such. not having ABS wont necessarily instantly make it un-roadworthy. it does sound like the company that sold it to you may have glossed over a few things though :) bit of a shame.
Doubtful the person on the phone would know how the law would treat this.
Now that you know about it, some policies state that if it is a known defect that contributes to the loss, you could be for some of that loss. Which company are you with?
Sounds like shenannigans going on between the dealership & the roadworthy.
Sounds like you're not the 1st
Sounds like they'll do it to others
Sounds like...
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
