Okay I picked up a diff for my S15 that I am swapping an RB26DETT into. I have gathered that the diff is a 4.3 ratio and has LSD as when I spin the halfshaft both turn. Can anyone tell me if the diff is a VLSD or an LSD, is there anyway easy way to know as I want to swap in some new Redline gear oil but want to know which one to use. Here are some pics if someone can tell me it would be great. I am not seeing the viscous sticker on it but not sure if it may have fell off.
https://www.sau.com.au/forums/topic/307454-r33-gtst-diff-for-my-s15/
They are viscous 4.11 ratio.
Remember once you get over 260 rwkw, they'll become unpredictable.
Mine is worn though, never tried new oils.
I thought the S15 had cool helical diff anyway..
Manual s15's do the autos still had viscous think the manual s15 helical diff was 3.962:1 from memory
The Manual Helical Diff has a 3.69:1 ratio. Unless you're running the S15 6 speed (which probably won't be able to handle the power of the RB26DETT) then the ratio will be too tall.
What you probably should have done, is swap the S15 Helical centre into your S15 Viscous diff. As it's a much better centre than the viscous one... I recently changed the VLSD in my R32 to the S15 Helical centre, and it has been an awesome improvement.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
