Hey guys,
So I was driving to Victor Harbor one day when a puff of steam/smoke came out of my bonnet on the left side. I pulled over and had a quick look, car was still running fine. Later I tried turning on my air-con and found out it was completely dead- and this is why...
Image link: (doesn't want to display here for some reason) http://www.overclockers.com.au/pix/image.p...d=mvjak&t=1
The pipe that's been blown open (no idea how) seems to be made of plastic, with some sort of silver insulation or something over it... does anyone know what that pipe is called? From general web searches, all I've seem to find is 'low side pipe (from evaporator)' and stuff like that, makes it a bit hard to track down a replacement. If anyone can let me know what sort of material it is, the name of it, or even better - where I could grab a replacement then that'd be awesome.
Cheers!
https://www.sau.com.au/forums/topic/307497-air-con-problem-r33/
that is a rubber hose with the aluminium over it to protect from heat .it is joined by crimped joins onto the aluminium ends.must of gotten too hot and blew out,should be able to get one from a wreckers or somewhere like that.not sure if nissan would still sell them, be worth ringing them at least ,or maybe you can get the hose replaced by a hydraulic hose fitter/maker.. :P
it looks like that hose is awfully close to the dump pipe & turbo, and it has slowly burnt (and the hose is probably as old as the car too, so likely to have tarnished slowly over time).
I'm no expert, but it's probably pressurised aircon/refrigeration gas that you lost through that split in the hose while you were on your way to Victor.
if you want a genuine part - go into a Nissan dealer - e.g. Lakeside Nissan on Main North Rd near Mawson Lakes. They'll get the replacement hose for you easily. Although once you replace it, you may want to look at shielding it with better insulation, or modifying it to sit a touch further away from your dump pipe & turbo.
Since you say the aircon is completely dead now though, the problem may be greater. hope you get it sorted before the rest of summer mate :P
Thanks heaps for the feedback and quick replies.
The photo I've taken is probably a little deceptive, as the blown hose sits further down than it looks, but even with that said I guess it is pretty close. It definitely is burnt though, so I guess that's the reason it finally blew - I just would have hoped/expected to notice the carbon on the hose earlier! Hopefully the gasket is fine, but if I notice anything (or I see it's being burnt again) after I get a new hose I'll look into it.
I think you're right too, Luciano - there was a pressurised gas-like hiss when the steam/smoke came out, so I was silly not to pick up on it straight after it happened. Thankfully, the climate control (LCD screen, fan etc) still works and everything, I probably just exaggerated a bit when I said it was completely dead! The car revs a bit higher when I press the A/C button, so I'm pretty certain it's just that cheeky hose.
I'm just spewing because I've got a 6 or so hour drive to Tumby Bay on Thursday... oh well, windows down and I'll be alright.
Cheers again
Edited by Daleet
I rang up the Nissan dealer on Unley Road (as it's closer to me), and they quoted me $344 + GST + 2 weeks on the part as it's coming from Japan. Youch! I haven't ordered yet (insufficient funds), but at least I know the figures.
Does anyone know of some decent wreckers that might stock some old R33 parts??
Hmmm, looks like until I get that hose replaced, I'll just have to put up with being a crispy critter.
You wouldn't be silly enough to replace the hose without first getting some heat shields on the turbo and that dump would you????
And switching on the compressor, not too smart. It will try to ingest the remains of your hose and assorted crap.
Aircon internals must be surgically clean.
Yeah that looks like the one I'm after. How much do you want for it? Though it looks a bit corroded or something... it's not clogged up or anything?
yeah its been siting around for a while but its clean inside, if you were in wa id say just come and get it , aall id want for it is enough to cover the postage , probably 20 or 30 bucks, im not going to use it again, its up to you, pm me or whatever,
Yeah it's unfortunate that I didn't see the hose had blown, so when I pressed the A/C button it's not like I knew it was a bad move. Depends on the price of heat shields etc too, if I put on a new hose and there's no burning, then I won't worry. If there is, I'll chase some up. Being a student means I don't have as much flexibility with my cash as I'd like. Ideally, I would get new/genuine parts from the dealer, but economically I just can't.
No worries dude, I'll pm you.
EDIT: Craig, I can't pm yet as I haven't had a total of 10 posts. I'll pm tomorrow when I've got some time to comment on a few other threads. Just got back from a big weekend away, so too tired to do so now.
Edited by Daleet
Got my mate who actually knows what he's doing (unlike myself) to give me a hand, and voila! Fixed. As you can see, I bought a roll of head shield and wrapped it over the dump pipe. Hopefully that does the job!
Air Con Fixed
Though it'll be good to get a really hot day so I can really give it a whirl.
Edited by Daleet
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
