  • Replies 75
would knock something up but time is up isnt it ?
and don't want my work used if someone is going to modify it after its sent in. unless discussed with me first.
that is all...lol
You still have time if you can get it in by Monday that is ok
A quick go using the font from Mitch's logo (can't find the font) - good on a white or black bg
brake lights from R35
The text at the bottom has a white border around it, cant see it on the white background. silly JPEGs
i like these 2 if i had to
ok comp will be extended til this sunday 28th Feb. Get your designs in. No more whinging, just get the designs in then they go to vote. You got a question, pm me or Shane.
Here is my quick contribution:
Only a quick play around in between drafting work. I'll have more of a stab at it later.
:cheers:
not bad , best so far ...one thing for everyone to remember the club can be held liable for copyright infringement if you hack someone else's artwork without asking. don't think we need a lawsuit..hahaha
I know enough about copyright laws ... studied it enough. That is my own artwork. :cheers:
Adaptions of the current logo. Now in Nissan font, which i have, making it much easier to get print/high quality logos.
At the end of the day guys, this logo will be plastered over members cars, so think about how your logo will look on the front windscreen of your car.
This may be just me but if the SAUSA is all in the same colour I always read it as SA USA. IMHO the SAU & SA need to be in different colours to avoid this.
Just my $0.02. (which rounded down really equals $0.00)
If the number of colours is an issue, I came up with this also ...
But I like the other one better :cheers:
yeah,,, NO !
The other one is much better ruby...lol
really do we need it to SAUSA at all ???
why dont we split the two apart
something like ruby has which makes sense to people outside the club who have NFI what SAUSA stands for
Skylines Australia,,,,,, SA
or SA chapter or whatever ???
plus the colours are USA flag colour which confuses everyone who doesnt know what they mean ?SAUSA is that some US thing ???
my two cents, or the square root of it anyway
    • Maybe it's time for a M3 F80 LCI, and leave it stock.  Drive it to a shop, sip on your latte with nutmeg whilst it gets serviced and on the way home swing by and grab some chai mix for the evening.
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
