Reason for Selling: CAN'T AFFORD TO OWN IT, AND NEED THE CASH
Asking Price: $15500 NEG
Contact Info: MARK ELLIS 0412993434 0732828882
Extra Information:
THE CAR IS ABOUT TO RUN OUT OF REGO SO I WANT TO SELL IT UNREGISTERED, SOME MODS INCLUDE: STRAIGHT CUT GEAR BOX WITH SHORT SHIFTER, CUSTOM BUILT TWIN PLATE CLUTCH CAPABLE OF 1000HP, FORGED ENGINE REBUILD, MILD CAMS, HKS GT 2540 ROLLER BEARING TURBOS, AFTERMARKET INJECTOR, N1 OIL PUMP, FRONT AND REAR STRUT BRACES, NISMO 360KM/H DASH. THE BODY IS IN PRETTY GOOD CONDITION WITH GOOD PAINT AND ONLY A FEW LITTLE DINTS AND SCRATCHES FROM THE PREVIOUS OWNER.
THE AIR FLOW METERS HAVE SEEN BETTER DAYS AND THE CAR COULD DO WITH A DECENT TUNE AS IT STILL HAS THE STANDARD ECU. THE PREVIOUS OWNER SAID IT USED TO MAKE 600HP SO MAYBE WITH AN AFTER MARKET ECU AND NEW AFM'S IT SHOULD BE A LITTLE ROCKET.
IT STILL HAS STOCK SUSPENSION AND THE FRONT SUSPENSION SQUEAKS A LITTLE BIT, THE WHEELS ARE IN NOT SO GOOD CONDITION WITH SOME BATTLE SCARS ON THEM FROM WHEN THE LAST OWNER HAD A FIGHT WITH A GUTTER IN THE CAR, LOL. AND THE CAR SOME TIMES TRACKS ON THE ROAD WHEN THE ROAD SURFACE IS UNEVEN, IV'E BEEN TOLD IT DUE TO THE OFF SET OF THE WHEELS.
THE INTERIOR IS IN GOOD CONDITION CONCIDERING TO AGE OF THE CAR BUT THE DRIVERS SEAT HAS A LITTLE WEAR ON THE SIDE OF IT UNDER THE SEAT COVER.
IF YOU HAVE ANY QUESTIONS PLEASE DON'T HESITATE TO CALL ME OR MESSAGE ME.
https://www.sau.com.au/forums/topic/307915-r32-gtr-1990-un-reg-15500-neg/
so this has after market turbos, injectors, built engine and a standard ecu?
somebody spent 10k+ on the engine, turbos and injectors, but couldn't be farked spending 1k on a computer?
got any receipts to prove build?
Yeah, i hear what your saying, the ecu should have definatly been put in, but the standard on has been chipped and re-mapped. sorry the only receipt i have for the mods is for the twin plate clutch, i've only been told from the previous owners about all the mods.
sorry i couldn't tell you more.
cheers mark.
yeh right - bog standard!
Extra Information:
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
