Hi,
So I bought my Skyline about a year ago, as a bit of a project because it was pretty beaten up, and as such I got it pretty cheap. My insurance has been really good so far except that they just insured it at what I paid for it, and not a market value.
Having spent a year fixing it and spending money on it, I wanted to increase the value on my insurance to it's normal market value, or something similar, but I need to get an evaluation apparently. I'm not entirely sure about how to go about this?
Does anybody here have any suggestions as far as getting it evaulated?
NB: I'm not interested in anybody's gung-ho "f*k InSuRanCeZ mAn U dUn NeEd ThAt ShIz" ideas.
Cheers,
Mods: Sorry if this has been covered, couldn't find anything searching.
https://www.sau.com.au/forums/topic/308437-insurance/
Hi,
Cheers,
Hi Tim
You need to go to a dealer to get a valuation from them and some dealers will charge you for it as well.
If you know a dealer (preferably one that sells Skylines) then maybe they can help you.
If you know anyone at C-Red then they may be able to help as last time I checked they had a Dealers License.
Hope this helps
https://www.sau.com.au/forums/topic/308437-insurance/#findComment-5090225
Cheers,
Thanks Rod, I'll be looking into that when I get home. Just out of curiosity, what do people think the market value actually is? I saw a completely stock 33 [i think this was actually less than had come out of the factory, had lots removed] for for 15k a few months ago.
Thanks for the help
https://www.sau.com.au/forums/topic/308437-insurance/#findComment-5090383
The ol' "mildly modified 33"? Reasonably good nick.
Was more interested in the market value that insurance companies will be going with like Kaido is talking about.
I renew my insurance in in dec 09 and Just Car had the market value of my r33 gts-t S1 1993 at $11,000 :P
https://www.sau.com.au/forums/topic/308437-insurance/#findComment-5090470
Any luck with this Tim? I am wanting to do the same thing, i am with JustCars as well and they will only insure my car to $10000 :/
But after i do the engine swap then i will want more cover than that. What other companies insure gray imports? Shannons won't insure me because im under 25
https://www.sau.com.au/forums/topic/308437-insurance/#findComment-5094248
When I swapped my insurance from just cars to sgio they said they could do it at market value which was 10k or what I paid for it which was 8.5k, so mine is insured for 10k even though they know i payed 8.5k for it over 6 months ago. This was for third party fire+theft btw
Edited by Crackfox
https://www.sau.com.au/forums/topic/308437-insurance/#findComment-5096723
My car was insured with JC for $2k (car value $10k), when I came to renew the policy early this year I used their website thing & added some of the extra mods I did to the car (exhaust, POD, SAFC 2, intercooler & boost controller) they upped my car's insured amount from $10k to $11.7k & didn't change my premium? Are they actually being generous or their computer software must be bugged?
https://www.sau.com.au/forums/topic/308437-insurance/#findComment-5104351
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
